Merging Files
Показано с 1 по 4 из 4
Тема: Merging Files
    Belgium
    Вопрос Merging Files
    Hi ,
    Can anybody explain how to merge 2 files ? I have 2 bga dumps and i need 1 file like FS0
    How to do that with 010 editor for example.
    Thanks a lot !
    Regards,
    Roy
    on Unix/Linux/OSX/QNX
    cat file2 >>file1
    after that file1 is merged content of 1 and 2
    regards
    Belgium
    Thanks for the answer,
    I need the next: file 1 the first to bytes and then file 2 the 2nd two and then file 1 3th 2 bytes and so on.
    So xx = file 1 ff = file 2
    xx ff xx ff xx ff xx ff
    That needs to be the result.
    Regards,
    Looks like you're using two gl512 data merge
    Not very well done, I read the file, two gl512 match the size of the data, cross merge to, not so good out
    Последний раз редактировалось audijiJQ; 19.10.2015 в 12:21.
    Чтобы узнать от вас
