ENGINE
Audi S2 5-cyl Turbo 4WD with ABY Engine
(Oct 92 - Jul 95)
Component 2.2l R5 MOTR.RHV HS D02 with
ECU 895-907-551-A
* Visit http://www.S2central.com for more info on the Audi S2 *
* Label file created by Paul Nugent on 31st January 2002, v01 *
Group 000 included here for reference purposes...
Labels for Group 000 are not yet supported in VAG-COM.
; 000,00,ABY Engine Group 0 : General Status
; 000,01,Coolant Temperature,Idle 184-215
; 000,02,Engine Load,Idle 20-26
; 000,03,Engine Speed (RPM),Idle 77-83
; 000,04,Operating range of IAC valve,Idle 121-135
; 000,05,IAC curve zero point,Idle 70-125
; 000,06,IAC load adjustment,Idle 123-137
; 000,07,IAC curve control,Idle 41-61
; 000,08,Lambda control,Idle 123-133
; 000,09,Lambda adaptation,Idle 100-141
; 000,10,Ignition Timing,Idle 35-37
001,0,ABY Engine Group 1 : General & Ignition
001,1,Engine Speed,Idle 770-830 RPM
001,2,Coolant Temp,70-106 deg C
001,3,Lambda Factor,~ 1.0
001,4,Ignition Timing,Idle 8-12 BTDC
002,0,ABY Engine Group 2 : General & Injection
002,1,Engine Speed,RPM
002,2,Injector Duration,Pulse Width
002,3,Battery Voltage,
002,4,Atmos.Pressure,Ambient
003,0,ABY Engine Group 3 : Load, Temp & Throttle Body
003,1,Engine Speed,RPM
003,2,Engine Load,
003,3,Throttle Angle,
003,4,Intake Air Temp,
004,0,ABY Engine Group 4 : Load, Speed & Throttle Switches
004,1,Engine Speed,RPM
004,2,Engine Load,
004,3,Vehicle Speed,
004,4,Throttle Switches,Idle=00010
005,0,ABY Engine Group 5 : Idle Air Control (IAC) & AirCon Detection
005,1,Engine Speed,Idle 770-830 RPM
005,2,IAC Zero Point,Idle 70 - 125
005,3,IAC Duty Cycle,
005,4,Load Switches,AirCon ON=0100
007,0,ABY Engine Group 7 : Idle Air Control (IAC) Valve
007,1,Operating Range,Idle 121 - 135
007,2,Curve Zero Point,Idle 70 - 125
007,3,Curve Control,Idle 41 - 61
007,4,Load Adaptation,Idle 123 – 137
VAG blocks
- russianscars
Сброс сервисных интервалов (Приборная панель 17)
1. Заходим в VagCom'е в Приборную панель - блок 17 (Instrument Cluster в англ. версии VagCom)
2. Выбираем раздел - Адаптация -функция 10 (в англ. версии VagCom Adaptation)
3. Затем запускаем Channel 002 - это Сброс сервисного интервала.
4. "напоминалка" сработала, вводим -> 0 - сброс интервала
Основные сроки интервалов настраиваются в каналах 42, 43, 44, + коррекции для longlife (если задействован) в каналах 46, 47, 48. Переключение между longlife и жестким интервалом - в 45-м канале.
В Росии условий для longlife нет! )))
В соответсвующих каналах устанавливаем требуемые значения в днях или километрах, описание каждого канала ниже:
Channel 040:
Километраж пройденный от предидущего сервисного обслуживания (от сброса интервала на приборке ).
Число x100км.
Channel 041:
Количество дней, прошедших от предидущего сервисного обслуживания (от сброса интервала на приборке).
Число = кол-во дней.
Channel 042:
Минимальная граница по километражу до срабатывания "напоминалки".
Предел: 5000км...->
Шаг: 00001 = 1000км (00015 = 15000 км)
Стандартное значение для longlife со всеми вариантами двигов - 15000км,
для жесткого интервала тоже 15000км (или поствьте 10000км... вобщем сколько захотите )
Channel 043:
Максимальная граница по километражу до срабатывания "напоминалки".
Стандартное значение для longlife:
30000км (19000mls) - для бензиновых двигов,
50000км (31000mls) - для 4-х-цилиндровых дизелей,
35000км (22000mls) - для 6-ти-цилиндровых дизелей.
Для жесткого интервала ставить столько же, сколько в предидущем, 042-м канала.
Channel 044:
Максимальное количество дней до срабатывания "напоминалки".
Шаг: 00001 = 1 день (00365 = 365 дней)
Стандартные значения: для longlife - 730 дней (2 года),
для жесткого интервала - 365 (год).
Channel 045:
Категория используемого масла. Задается алгоритм рассчета longlife - интервала.
00001 - жесткий интервал,
00002 - longlife - бензиновые двиги,
00003 - longlife - 4-х-цилиндровые дизеля,
00004 - longlife - 6-ти-цилиндровые дизеля.
Channel 046:
Только для бензиновых двигов!
Общий расход. Величина применяется для рассчета longlife-интервала.
Стандартное значение: 00936.
Channel 047:
Только для дизелей!
Количество сажи в масле в рассчете на 100км. Величина применяется для рассчета longlife-интервала.
Стандартное значение: 00400.
Channel 048:
Только для дизелей!
Температурная нагрузка двига. Величина применяется для рассчета longlife-интервала.
Стандартное значение: 00500.
информация от filosof:
смена языка
Канал для адаптации языка панели - 4 канал.
Code Language version
00001 German
00002 English
00003 French
00004 Italian
00005 Spanish
00006 Portuguese
Channel 040:
Число x100км.
Channel 041:
Channel 042:
Предел: 5000км...->
Channel 043:
Channel 044:
Channel 045:
Channel 046:
Channel 047:
Только для дизелей!
Channel 048:
Только для дизелей!
смена языка
00001 German
00002 English
00003 French
00004 Italian
00005 Spanish
00006 Portuguese
- Serg_A200
На своей приборке (S6 1997) использую следующие каналы для сброса межсервисных интервалов:Блок 17 - панель инструментов (приборов) --->Кнопка 10 - Адаптация:
05 канал - OIL в тысячах километров
06 канал - In1 в тысячах километров
07 канал - In1 в десятках дней
08 канал - In2 в тысячах километров
09 канал -Установка начального пробега / Gesamtwegstrecke. Этот канал я никогда не трогал.
