Delphi P0879D solution
Hello...
Anyone have solution for this?
Does anyone sell solution for Delphi, not just patch files?
Thank You!!!
Thank You!!!
mib2pmaster
- Пользователь
Today after many months I tried again.
I unpacked delphibin.ifs and did needed modifications to SWaP region and repacked.
Everything works OK for 5Min(Incl. AppConnect, Maps etc....), then reboots into Blue Emergency Mode and starts recovering. I don't see what I've done wrong.
With restart I'm able to use again 5min then EFU and so on....so on.....
Any hint will be appreciated!
Hint: If U don’t know know how to this - leave it for professionals!magna413 писал(а):Today after many months I tried again.
@magna:
As I wrote before - don't touch the original files, it's not necessary! Activation can be made very easily, just run the SWaP from SD card. Delete the *.fec files from all of the subdirs in /persistence/SWaP, then slay original SWaP, then copy your modified FEC file to /persistence/SWaP/pg directory and then run your patched SWaP in console from sd card. Let it run for 3-5 seconds, then press CTRL+Z, then reboot the unit using shutdown -S reboot.
After the reboot your unit will have enabled all the codes from your FEC file and the watchdog won't be triggered, as the system files were not modified.
