[font="]hello boys, [/font]
[font="]i need help with mib2..retrofitting mib2 to my car and need VCRN to calculate FEC. Where can i find him? [/font]
[font="]VCDS / measurement values? but there are many values here and none of them looks like VCRN label.....[/font]
[font="]Someone told me that it can be found in log file (look at two last record), I don't see a log like that belowin FS...can you help me identify him, whitch log it is?
Jan 01 00:01:00 2 19 1800 part uda, config 00, slba 0, nlba 15204352, elba 15204351
Jan 01 00:01:00 2 19 1800 part rpmb, config 03, slba 0, nlba 256, elba 255
Jun 23 02:34:13 2 20 1800 mmc_set_partition(12e120, 3)
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fec] start reading FECs from store
Jun 23 02:34:13 2 20 1800 mmc_set_partition(12e120, 0)
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] read block 0 from RPMB
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] read block 1 from RPMB
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] using index block 2
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] read block 2 from RPMB
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] first half block is 4
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] second half block is 5
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] end of FEC reached with second half block
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] read FEC: [type: 0x7, status: 0, reason: 2, diagnosis: 0xbf, pos: 1, prim fsid: 0xffffffff, other fsids: 0x00040100, 0x08400008, 0x00050000, 0x00030000, condval on creation: 0]
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] added 2 half blocks for fec
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] half block 4 is used
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] half block 5 is used
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fecstore] 1018 free half blocks available
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fec] finished reading FECs from store
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] setting the RPMB key was successfull
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] got SPRK_RESPONSE
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] reading key from file /tsd/etc/swap_keys/FEC_key_public_signed.bin
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] signature of key file is valid
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] key successfully read from file
Jun 23 02:34:13 7 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap.fec] notifying observers that FEC manager is ready to do signature check
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] processing exception list /tsd/etc/slist/signed_exception_list.txt
Jun 23 02:34:13 2 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] parsing exception list failed: syntax error (line 1)
Jun 23 02:34:13 5 10000 1 swap: 02:34:13.732 [Error] [iMX6.Swap.tsd.mibstd2.system.swap] parsing exception list failed: syntax error (line 1)
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] got KM_VALUE_CHANGE
Jun 23 02:34:13 6 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] setting mileage to 0km
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] got OPERATING_HOURS_VALUE_CHANGE
Jun 23 02:34:13 6 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] setting operating hours to 1137h
Jun 23 02:34:13 6 10014 9 [403d0004] [iMX6.Swap.tsd.mibstd2.system.swap.theftpr.proxy] received event 0x7050001
Jun 23 02:34:13 6 10014 9 [403d0004] [iMX6.Swap.tsd.mibstd2.system.swap.theftpr.proxy] its a response
Jun 23 02:34:13 6 10014 9 [403d0004] [iMX6.Swap.tsd.mibstd2.system.swap.theftpr.proxy] HMAC of event is valid
Jun 23 02:34:13 7 10014 9 [403d0004] [iMX6.Swap.tsd.mibstd2.system.swap.theftpr.proxy] removed token used for HMAC check
Jun 23 02:34:13 6 10014 9 [403d0004] [iMX6.Swap.tsd.mibstd2.system.swap.theftpr.proxy] forwarding event to receiver
Jun 23 02:34:13 7 10014 9 [403d0004] [iMX6.Swap.tsd.mibstd2.system.swap] enqueued message 0x7050001
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] got VCRN_RESPONSE
Jun 23 02:34:13 5 10014 9 [403d0013] [iMX6.Swap.tsd.mibstd2.system.swap] VCRN: 0xa5d336db61[/font]
MIB2 VCRN
Модератор: sergeynik
analogovey
- Новичок
analogovey
- Новичок
