Hi, in VW I was executed the firmware recall that blocked my root access via usb / uart or usb / eth (dlink100)
after the VW recall I have the
hardware revision 3G0035043K
MU 0199
SW train MHI2_ER_VWG11_S0259
before the recall was made
hardware revision 3G0035043A
MU 0199
SW train MHI2_ER_VWG11_K0259
I have the k3332 mu1187 firmware for my hands (is for harman kardon, MHI2_ER_VWG11_K3332) .... is it possible to install it for delete fix? since the power train is blocked and does not allow me to install it in a conventional way, with the green menu (SWDL) or IPL system it is possible to install it without causing damage : P ??
through JTAG it would be an impossible and too expensive solution for me
the supported train is not fair in the metainfo but it should be fine
SupportedTrains = "MHI2_ER_VWG11_P3250*,MHI2_ER_VWG11_P3301*,MHI2_ER_VWG11_K3332*"
VW firmware recall and root access blocked, solution?
Модератор: sergeynik
simaservis1108
- Новичок
