Search to convert mib 2 to mib2.5
Модератор: sergeynik
- Пользователь
Hello
I search to convert solution for mib 2 3g0 harman to 5na.
I need also différents firmware for mib2
I pay for that
I pay for that
- Пользователь
- Пользователь
- Пользователь
- Пользователь
- Новичок
- Пользователь
- Новичок
Convert MIB2 High (Harman) to MIB2.5
for 9.2” Display
Do at your own risk! You can brick the unit!
Note: it is possible that something is missing in this manual or different
for other firmware versions!
Setup unit on bench - Connect to RCC via UART
• Make Full (Advanced) Backup with M.I.B. to SD Card | http://mib.mibsolution.one
• Save Backup of SD Card on PC
• Format SD Card with FAT32 and Load MIB2.5 (G13) Firmware, Insert into SD1 on Unit
• Using E2PTool Program and D-Link (or UART Terminal) change part number and SW train to
fit MIB2.5 for brand and region (example for VW, 5NA035047 & MHI2_ER_VWG13_Pxxxx)
• Reboot Unit (hold power button for 30 seconds)
• Enter SWDL via Service Mode , Select Manual Download
Select MIB2.5 Firmware Update and Select ALL (all parts should say YES)
• Start Update
• Let Update Flash, at some point unit will enter RCC Emergency (some units update will fail at
MMX_App, at this point unit will restart. As soon as unit powers back on short UART RCC Tx
to GND, in UART terminal press key within 5 seconds to enter Command Line. Type “boot -t
emerg” and press enter to enter RCC Emergency)
NOTE: You MUST switch to 9.2” screen for Display to show at this point!
• As soon as BLUE RCC Emergency Screen is displayed with countdown timer, enter root as
login and MIB2.5 Firmware RCC Password then “slay -9 MIBEmergency” into UART Terminal
to stop countdown.
NOTE: This can be tricky and must be done before Countdown timer finishes, if you need to try again reboot unit
and enter RCC Emergency once again
• With Countdown Timer Stopped Enter Following Commands in order via UART Terminal:
mount -uw /net/mmx/fs/sda0/
on -f mmx sh
fdisk /dev/mnand0
(fdisk will start, unit Q key on keyboard to exit)
umount -f /dev/mnand0
fdisk /net/mmx/dev/mnand0 delete -a
fdisk /net/mmx/dev/mnand0 add -s1 -t177 -c0,685
fdisk /net/mmx/dev/mnand0 add -s2 -t5 -c686,28005
fdisk /net/mmx/dev/mnand0 add -s2 -e1 -t178 -n312
fdisk /net/mmx/dev/mnand0 add -s2 -e2 -t178 -n1280
fdisk /net/mmx/dev/mnand0 add -s2 -e3 -t178 -n2048
fdisk /net/mmx/dev/mnand0 add -s2 -e4 -t178 -n128
fdisk /net/mmx/dev/mnand0 add -s2 -e5 -t178 -n512
fdisk /net/mmx/dev/mnand0 add -s2 -e6 -t178 -n512
fdisk /net/mmx/dev/mnand0 add -s2 -e7 -t178 -n1024
fdisk /net/mmx/dev/mnand0 add -s2 -e8 -t178 -n576
fdisk /net/mmx/dev/mnand0 add -s2 -e9 -t178 -n15808
fdisk /net/mmx/dev/mnand0 add -s2 -e10 -t178 -n5120
fdisk /net/mmx/dev/mnand0 add -s3 -t179 -c28006,30315
mount -e /net/mmx/dev/mnand0
echo "y" | mkqnx6fs -T runtime -b 1024 -i 22912 /dev/mnand0t177
echo "y" | mkqnx6fs -T media -b 32768 -i 1024 /dev/mnand0t178
echo "y" | mkqnx6fs -T media -b 32768 -i 2048 /dev/mnand0t178.1
echo "y" | mkqnx6fs -T media -b 32768 -i 256 /dev/mnand0t178.2
echo "y" | mkqnx6fs -T media -b 32768 -i 2048 /dev/mnand0t178.3
echo "y" | mkqnx6fs -T runtime -b 32768 -i 65536 /dev/mnand0t178.4
echo "y" | mkqnx6fs -T media -b 4096 -i 32768 /dev/mnand0t178.5
echo "y" | mkqnx6fs -T runtime -b 16384 -i 8192 /dev/mnand0t178.6
echo "y" | mkqnx6fs -T media -b 1024 -i 32768 /dev/mnand0t178.7
echo "y" | mkqnx6fs -T media -b 32768 -i 8192 /dev/mnand0t178.8
echo "y" | mkqnx6fs -T media -b 32768 -i 16384 /dev/mnand0t178.9
echo "y" | mkqnx6fs -T runtime -b 32768 -i 16384 /dev/mnand0t179
umount -f /mnt/app
cat /fs/sda0/MMX2/app/70/default/app.img > /dev/mnand0t177
IMPORTANT (wait for this command to finish! May take several minutes!)
cd HBpersistence/SWDL
rm MainUnit-version2.txt
rm MainUnit-version2.txt.SWDL.compatibility.txt
rm MainUnit-version2.txt.SWDL.version.txt
rm MainUnitIgnoreImages.txt
/net/mmx/fs/sda0/RCC/tools/0/default/updatePersistence -type b -key 0xc002000d -value 1
/net/mmx/fs/sda0/RCC/tools/0/default/updatePersistence -type b -key 1 -value 0
• Reboot Unit (hold power button 30 seconds), Unit will reboot into MIB2.5 Firmware
• Enter SWDL Once Again, Manual Download, Select All, and Reflash MIB2.5 Firmware Update
Once Again, this will make a clean and complete Firmware Install.
• DONE
for 9.2” Display
• Start Update
to stop countdown.
on -f mmx sh
fdisk /dev/mnand0
umount -f /mnt/app
• DONE
I would never flash MMX manually for G13 conversion.
*) Edit Train to K3xxx and flash K3xxx(for better compatibility)
*) Enable dev mode
*) Flash G13 ifs-root and edit train to G13 - reboot
*) enable user-swdl and check all modules and start flash
*) after rcc_prescript eject sd card and format NAND for G13
*) insert SD and continue
Or better make script in to update files.
*) Enable dev mode
