Mib2 Audi Tt
Модератор: sergeynik
chris2011
Mib2 Audi Tt
Сообщение chris2011 »
Hi, I tried to activate developer mode in audi tt unit but it is not working. Normally S12345 is login code to enable it.
But in TT this not works.... Sw 1xxxx
mobista
Сообщение mobista »
Login is: 20103
chris2011
Thx mobista, I updated my tt unit to vw 1187 via fw update but now I have the problem that the buttons on the lcd screen are not be working, just the radio menu it shows me.
Any idea how I can fix it??
mobista
Сообщение mobista »
chris2011 писал(а):Thx mobista, I updated my tt unit to vw 1187 via fw update but now I have the problem that the buttons on the lcd screen are not be working, just the radio menu it shows me.
Your unit is on bench or in car? If in car which car is it?
chris2011
I tested it on bench and in audi a3, the same problem buttons not working.
If I put in another rcc from a a3 all buttons working again.
If I try then to update via sd card I get message meta file can't be read.
There must be problem in rcc
mobista
Сообщение mobista »
chris2011 писал(а):I tested it on bench and in audi a3, the same problem buttons not working.
I think it's not RCC problem - if U have selcted "All" of FW parts when conversion were made RCC was flashed with full packet of files.
MMI
Сообщение MMI »
Hi,
Conversion gone wrong, the IOC is wrong that is why it does not work anymore. You should send it to specialist in order to get it working again. This is the only solution for this.
You can not "flash" it to just any firmware as these units are based on platforms and have different settings/bios parameters. By doing what you did I think you crippled your unit.
Find a specialist and let him or her fix it.
With kind regards
chris2011
I already fixed it problem was in eeprom, now all working
