Hi all,
does anyone know whether you can use the VIN change method in ODIS-E/S to download specific datasets for different bosch modules like the BCM1 etc... and capture them for use with flashing via ODIS-E? Things like heated seats, ambient lighting, matrix headlights rely on specific datasets in BCM1 to be retrofitted. Without hte correct dataset these will not work at all or correctly. For example, for ambient lighting retrofit, you can retrofit and changing long coding gets lights to work 50% correctly. With correct dataset, ambient lighting works 100% like factory.. Datasets allow different modules to be shared between different makes of cars and could also be used as software as a product.
thanks
A
capturing BCM1 datasets?
spyderboyant
- Новичок
