MMI 3G+ issu
MMI 3G+ issu
Hi all !!
My MMI 3G+ screen dont start after an Emergency update..
There is log :
=> boot 1c0000
starting image @801c0000 ...
Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: InterruptLevelMask Register
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046ae0
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_09423A) MMI3G Audi EMERGENCY SETUP 15325A
starting pci driver
*** init FPGA registers ***
[pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting atapi driver - setup device /dev/cam0
InterruptAttachEvent failed
Interrupt attach failed: (Polled mode operation) : Invalid argument
Unable to access "/dev/cam0" (2)
starting devc-pty
starting flash driver
starting SDCard driver
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
49169 running /usr/bin/devg-NVTIRM
DMA is Disabled
dma disabled, interrupt thread priority = 100
49171 running /sbin/io-media-nvidia
49172 running /usr/sbin/io-display
49173 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
discplayer_init: IN
nvidia_render_manager_init: IN
INvmRenderManager::GetNvmRenderManager (&pRenderManager);
er = pRenderManager->Init(oConfig);
# App FPGA valid 1
Emergency FPGA valid 1
Disabling IOC watchdog
EmergencyApp-MMI3G: version 37.26.2098, date of build 07.08.2015
pRenderManager->Open()
nvidia_render_manager_init: OUT
discplayer_init: OUT
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
created navigator control point with 8249288
mixer_init: IN
mixer_init: OUT
NvTRACELEVEL set to 3 (Level Info)
nVAudio_init: IN
nvidia_render_manager_init();
nVAudio_init: OUT
installing audio decoders
installing video decoders
nVAudio_init: IN
nVAudio_init: OUT
OnIpcGetCaptureUnitSourceCount
Number of displays: 6
Number of layers: 9
=> scan
** @0x80040000: FPGA
total size: 746480 [0x0b63f0]
data: 746212 [0x0b62e4]
.FDR = PL_MMI3G_PLUS_FPGA_9411_D1_09362A
.FDU = Userinfos zu FPGA 9411_D1_4010_14lw
** @0x80100000: FPGA
.FDR = PL_MMI3G_PLUS_FPGA_9411_D1_09422A
** @0x801c0000: IFS [vers.1, UCL, old EMERGENCY]
total size: 4887860 [0x4a9534]
- header: 256
- startup: 53512
- imagefs: 11776548
RAM: 11830060 [0xb4832c]
** @0x80780000: IFS [vers.1, LZO, old APPLICATION]
total size:42085196 [0x2822b4c]
- header: 256
- startup: 53512
- imagefs: 96456444
RAM: 96509956 [0x5c0a004]
** @0x87f00000: BIOS packet
total size: 786432 [0x0c0000]
BIOS pattern: FFFFFF7F.FFFFFFFF
App. pattern: FFFFFF7F.FFFFFFFF
Many thanks for your help !!!
There is log :
=> boot 1c0000
starting pci driver
starting devc-pty
the application.
DMA is Disabled
discplayer_init: IN
# App FPGA valid 1
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
mixer_init: IN
mixer_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
Number of layers: 9
=> scan
- header: 256
- startup: 53512
- imagefs: 11776548
- header: 256
- startup: 53512
- imagefs: 96456444
Thank you Tschako !!
How can I erase header ?
And a little question, when I am woth SW K0942, i update the map 6.26.1 after 2 min, MMi reboot constantly.
For stop this, I remove map from HDD and MMi stop reboot.
I do another update with the same map, but I removed the HDD map partition, and I have error 150 when update.
Have you got an idea ?
Try the following steps:
!! Attention !! SD Card with K0942 FW must be inserted!
Enter IPL Mode:
boot 1c0000
echo dummy > /HBpersistence/DeveloperMode
flashit -a 780000 -e 1000
reboot the unit
EMG update should start succesfull to rebuilt the flash images ...
Cause the HDD problems:
Delete Nav Partition by using the adaption value in APK 9 from 0 to 1 and reboot
reinstall maps
Good luck!
Tschako
Enter IPL Mode:
boot 1c0000
reboot the unit
reinstall maps
Good luck!
Tschako
http://turbo-quattro.com/showthread.php ... nit-repair
Complete manual todo: http://yadi.sk/d/BkzEeID1GgbYf
Read the whole stuff and you will be able to fix your problem...
I do this for IPL
https://image.noelshack.com/fichiers/20 ... 125447.jpg
When i do command, I have this :
=> boot 1c0000
starting pci driver
starting devc-pty
the application.
DMA is Disabled
discplayer_init: IN
# App FPGA valid 1
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
mixer_init: IN
mixer_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
Number of layers: 9
#echo dummy > /HBpersistence/DeveloperMode
No such file or directory
*** erasing...
*** Verifying...
If I reboot, no more, no green EMG IFS no, MMi screen dont come.
Now i do IPL, (turn IPL , reboot, turn normal) and nothing juste a green rectanlge no =>
Many thanks for your Help Tschako !!
=> boot 1c0000
starting pci driver
starting devc-pty
the application.
DMA is Disabled
discplayer_init: IN
# App FPGA valid 1
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
mixer_init: IN
mixer_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
Number of layers: 9
*** erasing...
*** Verifying...
The IPL located at adress "0" of the flash area is the first initial application the system starts up.
With the a.m. flashit command you only erased the header of the wrong ifs image which starts much higher at 780000.
The IPL must allways work as before. Without a working IPL you have no chance to start up the unit and do anything.
Try to disconnect the HDD. Maybe there is a short circuit on the bus structure or something else.
Check the connection of the terminal for sure!
If all this things don´t fix your IPL, you only have the possibilty to reflash IPL via JTAG flash. But this is another story...
Connection are good, can my computer dontd connect to IPL ? At the beginning I put switch on IPL, I press Reboot, and turn IPL switch to normal
If I do flashit -a 4000 -e 1000 ? I dont do that but if..
If I need JTAG, how much cost this ? And can I do that ? Because, IPL dontd work now, I hear the HDD working, I hear sound, but nothing..
simaservis1108
- Новичок
