MU9306 after IOC and NINC are flashed
renming
Сообщение renming »
Hi, could someone please help me figure it out why that after flashing a firmware that stated 9307 and 9308 could change the MU9308 to MU9306? I mean the firmware is clearly for 9307 and 9308, so that I could even flash all MU parts fine, but after flashing MUIOC and MUNINC, the main MU version changed from 9308 to 9306, then the firmware disk is not recognized any more, it listed N/A after MU9306, and MUIOC, MUNINC.
How can I reflash the MUIOC and MUNINC back to 9308? I dont have the the 9306 disk, so I dont know what path that has to be in metafile in order to get system to recognize the 9308 firmware anymore.
Anyone has 9306 firmware? I need to see the metafile of the firmware which has 9306 in it.
MMI
Сообщение MMI »
Hi,
YOu can try this:
Go in green menu, select ignore region and version, and tap manual. Then go out. Then SW update menu, select manual then deselect all. After that select MUINIC bootloader(BOLO) and APP, and MUIOC BOLO AND APP.
Update and you should be good to go.
Regards,
Roy
Crash-100
Сообщение Crash-100 »
i mean this is mistake.
