Script for Jukebox export?
Makaveli
Сообщение Makaveli »
Hi,
Is it possible to write a script for jukebox export?
the problem is, with the basic functions of the mmi, u can only import titles in the jukebox, but there is no option to export the titles...
Audi says this is because of any copyright problems, bullshit...
thanks in advance
regards
UkNik
Сообщение UkNik »
You can run the script http://yadi.sk/d/7ALdHFduMvisg - it'll copy all music from MMI's hdd to the root of your sd. But this process is not fast.
P.S. Tell me, if you have any troubles with this script.
Makaveli
Thanks, i will try it!
