старенький аппарат, но очень не плохой,
у стэлса есть с него копия
http://www.sergeynik.com/atv/ATV%20Pola ... 096-03.pdf
ATV Polaris Sportsman 500 96-03
список аналогов
Wheel Bearings:
Sp700 Rear wheel bearings Federal-Mogul Bearings 510013
Sp700 Front wheel bearings BCA 510014
Rear - Napa # FW143
Polaris front strut Bearings replaced by: John Deer JD8935 skf L44649
Polaris front wheel hillard hub bearings replaced by: John Deer JD8933 skf L44643
SP500 with the hubs that lock. Front wheel bearings that go inside hub - Timken L44649 & L44643
ATV Polaris HUB Seal 73 X 58 X 8
Oil Filters:
Sp400&500 Oil Filter STP SMO17
sp600 or sp700 oil filter Super Tech ST7317 at Wallmart
Wix filter – 51357
K&N- 196
Amsoil- # EaOM103 (chrome filter is EaOM103C)
Fram oil filter for single cylinder is PH6017A
Air Filter:
K&N- 1003
Precharger- 1003PK
Front Diff:
2 Federal Mogul 108 (output bearing)
2 CR# 15801 (output seals)
1 Federal Mogul 306 (input bearing)
1 Federal Mogul 9748 (input seal)
1 CR Speedi-Sleeve 99098 (for input shaft seal)
1 NTA 815 (needle bearing)
Chicago Rawhide oil seal that works for the (output seal) on front diff. CR# 15801(SP700)
Chicago Rawhide Front axle seal- 692461 @ $4.53 and Front shaft- 692321 @ $ 4.04
Rear Diff:
2) Bearings - 6010-2RSC3 SRI-2 The brand is KYK
1) Bearing - 6306-2RSC3 SRI-2 The brand is KYK
2) Seals - Polaris PN 3233878
1) Seal - Polaris PN 3233785
1) Bushing - Polaris PN 3233577
Chicago Rawhide Rear axle seal- 19630 @ $7.14
John Deere front diff replacement parts:
JD part # Roller Kit #MIA 10666
Cage Kit #MIA 10667
Seal Kit #MIA 10654
U-joints:
NAPA u-joint(338) works on the inner joint of front stock c.v. axle. (SP700)
U-joint for 2002 700 sp rear prop shaft - 1-0170 this is a SFK brand
Sp700 Rear drive shaft u-joints NAPA#338
Napa equivalent, with grease zerk # 1501
Boots:
CV Boot kit for the front of 05 model sportsmans - 8409 this is a Precision brand
CV Boot kit for the rear of all 600-800 model sportsmans that I'm aware of - 7427 this is a Precision brand (or # 4445)
Stock CV boot (front) for 02 700: Discount Auto Parts P/N 6-1052 Fits Dodge Neon, not sure what year.
stock cv boot for 03 sp700 car quest part# 85-0904
86-96 ford escort c.v. boot to replace a gorilla
Fans:
Sp?? Fan http://www.offroadwarehouse.com
Sp500 Fan p/n 30100515 800-341-7757
Spal fan (factory fan)- Spal VA07-AP12/C-58A Fan (30100452). Number to order is 1-800-345-0327 or http://www.spalusa.com
Spal # is 30100411 fits-
2004 Sportsman 400
2004 Sportsman 500
2005 ATP 500 4X4
2005 Sportsman 400
2006-07 Sportsman 450
2005-07 Sportsman 500 H.O. and EFI
2006-07 Sportsman X2 500
Thermal fan switch:
fan switch to replace a 2000-2003 Polaris 4010161, for a Nissan 84-88 Maxima or 86-89 Nissan Stanasa. (Blue Streak TS-127, Nappa FS147, Wells SW526). ?? Thermal sensor - tells fan when to come on - Wells SW526 less than $30
Exhaust seals:
NAPA part # 31360
Fuel pumps:
Sportsman 800 fuel pump- Airtex E8198 $79.97 (89-92 hyundai sonata 4 cyl)
Carter fuel pump # E7000 is the same as a 05 700 efi
NAPA fuel pump, part # 72118 works perfect on a 800 EFI
Airtex fuel pump for a 700 efi- fits a 93-04 hyundai elantra or sonata 4cyl.
Fuel Filters (EFI’s):
EFI fuel filter- NAPA #3199 will work, but is some smaller.
Bosch: 045905273
FRAM: G7143
ACDELCO: GF561F
WIX: 33199
Iridium Spark Plugs:
Sportsman 600/700/800 is BKR7EIX
Spark Plugs for Sportsman twins:
NGK BKR7E(all)
Autolite 3922
Denso K22PR-U
Spark Plugs for Sportsman 500:
NGK BKR5ES (96-04)
BKR6ES (00-05 H.O. and 05-06)
Champion RC12YC (all)
Denso K20PR-U (all)
Autolite 3923 (all)
Spark Plugs for Sportsman 400:
NGK BKR5E(02-up)
NGK BKR5ES(02-up)
Champion RC12YC(02-up)
Denso K20PR-U(02-up)
Autolite 3923(02-up)
NGK BR8ES(94-97)
Denso W24ESR-U(94-97)
Autolite 4063(94-97)
Solenoids:
2005 700 efi solenoid Napa# 18-5817 (Mercury/mariner 89-96158 vertical post)
Starter solenoid Napa part SME 7016841, I used this one on my 99 Sportsman 500
Starter solenoid - local lawnmower-small engine parts house mtd part number 435435
20 amp circuit breaker:
Advanced Auto parts- Buss 20 amp 12v circuit breaker
Tools:
Polaris specialty tools- http://www.victorspecialtytools.com
Great sites:
http://www.goallballs.com
http://www.erlandsonperformance.com
http://www.polarispartshouse.com
http://www.cheapcycleparts.com
Wheel Bearings:
Rear - Napa # FW143
Oil Filters:
Wix filter – 51357
K&N- 196
Air Filter:
K&N- 1003
Precharger- 1003PK
Front Diff:
Rear Diff:
Cage Kit #MIA 10667
Seal Kit #MIA 10654
U-joints:
Boots:
Fans:
2004 Sportsman 400
2004 Sportsman 500
2005 ATP 500 4X4
2005 Sportsman 400
Thermal fan switch:
Exhaust seals:
NAPA part # 31360
Fuel pumps:
Bosch: 045905273
FRAM: G7143
ACDELCO: GF561F
WIX: 33199
NGK BKR7E(all)
Autolite 3922
Denso K22PR-U
NGK BKR5ES (96-04)
Denso K20PR-U (all)
Autolite 3923 (all)
NGK BKR5E(02-up)
NGK BKR5ES(02-up)
NGK BR8ES(94-97)
Solenoids:
Tools:
Great sites:
