wildcat 1000
wildcat 1000
официальная страница
http://www.arcticcat.com/sidexside/category/sport/
рекламный видос
http://www.youtube.com/watch?feature=pl ... ekqB3ljiMM
http://www.youtube.com/watch?v=-mqqThXilH4
оригинальные номера запчастей (тоо че я покупал, наломал за сезон)
0530-064 ecu
4506-788 крыло пер правое Arctic Cat Fender, Front - Right
2402-018 диск задний Arctic Cat Wheel - Rear
0503-558 рычаг передний правый нижний Arctic Cat A-Arm, Lower Right
список ошибок и расшифровка
C0063-Tilt Sensor Circuit High
C0064-Tilt Sensor Circuit Low
P0107-MAP sensor Circuit Low
P0108-Map Sensor Circuit High
P0112-IAT Sensor Circuit Low
P0113-IAT Sensor Circuit High
P0114-IAT Sensor Circuit Intermittent
P0116-ECT Sensor Circuit Range/Performance
P0117-ECT Sensor Circuit Low
P0118-ECT Sensor Circuit High
P0119-ECT Sensor Intermittent
P0121-TPS Range/Performance
P0122-TPS Circuit Low
P0123-Tps Circuit High
P0219-Engine Over-speed Condition
P0231-Fuel Pump Relay Circuit Low
P0232-Fuel Pump Relay Circuit High
P0233-Fuel Pump Relay Circuit
P0261-L4 Rear Cylinder Injector Circuit Low
P0262-L4 Rear Cylinder Injector Circuit High
P0263-L4 Rear Cylinder Injector Balance
P0264-Cylinder Injector Circuit Low/SG
P0265-Cylinder Injector Circuit High
P0266-Cylinder Injector Balance
P0336-CKP Sensor Synchronization
P0337-CKP Sensor Circuit
P0339-CKP Sensor Intermittent/Erratic
P0480-Fan Relay Control Circuit
P0484-Fan Relay Control Circuit High
P0485-Fan Relay Control Circuit Low
P0500-Vehicle Speed Sensor
P0508-Idle Control System Circuit Low
P0509-Idle Control System Circuit High
P0562-System Voltage Low
P0563-System Voltage High
P0601-ECE Memory Check-Sum Error
P0615-Starter Relay Circuit
P0616-Starter Relay Circuit Low
P0617-Starter Relay Circuit High
P0630-Vin Not Programmed or Incompatible
P0635-Power Steering Controller Circuit
P0642-Sensor Power Circuit Low
P0643-Sensor Power Circuit High
P2300-Rear Ignition Coil Primary Circuit Low
P2301-Rear Ignition Coil Primary Circuit High
P2303-Front Ignition Coil Primary Circuit Low
P2304-Front Ignition Coil Primary Circuit High
P2531-Ignition Switch Circuit Low
P2532-Ignition Switch Circuit High
U0155-LCD Gauge Communication Lost FUEL OFF-Tilt Sensor Activation.
These Oil Filters
have 20 x 1mm threads,
11 psi by-pass valve,
anti-drain back valve.
AMSOil SMF 109
Bike Master 314-0025
Champion PH7016
Cycle Power 314-1919
Emgo 10-55662
Emgo 10-55660
Fram PH6018
Hi-Flo HF138
J.C.Whitney ZX063166P
K&N 138
NAPA 1359
WIX 51359
Per-Form J-509
ProPart 01-0029
Purolator ML16818
STP SMO-18
Suzuki 16510-03G00-X07
VESRAH vsf-3009
рекламный видос
0530-064 ecu
These Oil Filters
AMSOil SMF 109
Champion PH7016
Emgo 10-55662
Emgo 10-55660
Fram PH6018
Hi-Flo HF138
K&N 138
NAPA 1359
WIX 51359
Per-Form J-509
ProPart 01-0029
Purolator ML16818
STP SMO-18
VESRAH vsf-3009
Турбо киты.
эти пока тока готовят
http://www.pushturbo.com/WILDCAT.html
этот живой идут на контакт и тд
http://www.mcx-usa.com/arctic-cat-wildcat-turbo.php
главная сложность в мозге, siemens континентал М3С
за контролером чтоб както это срастить тудаже идем.
http://www.mcx-usa.com/gen-5-efi.php
