closep
BIOS: No packet found!
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_13382A, built 2013/09/17_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09422A
(0ms)
*** emergency FPGA loaded!
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001a
starting image @1c0000 ...
Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046ae0
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_09423A) MMI3G Audi EMERGENCY SETUP 15325A
starting pci driver
*** init FPGA registers ***
[pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting atapi driver - setup device /dev/cam0
[pcidma] finished.
[pcidma] finished.
xpt_configure: No eide interfaces found
Unable to access "/dev/cam0" (2)
starting devc-pty
starting flash driver
starting SDCard driver
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
53265 running /usr/bin/devg-NVTIRM
DMA is Disabled
dma disabled, interrupt thread priority = 100
53267 running /sbin/io-media-nvidia
53268 running /usr/sbin/io-display
53269 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
discplayer_init: IN
nvidia_render_manager_init: IN
INvmRenderManager::GetNvmRenderManager (&pRenderManager);
er = pRenderManager->Init(oConfig);
# Fpga header is not 0x4744482e (0xffffffff)!
App FPGA valid 0
Emergency FPGA valid 1
Disabling IOC watchdog
EmergencyApp-MMI3G: version 37.26.2098, date of build 07.08.2015
Unable to post device
common/include/NvRefCountImpl.h:134: NV_ASSERT failed: __INvRefCountIMPL_m_ulRefCount == 0
Process 53267 (io-media-nvidia) terminated SIGSEGV code=1 fltno=11 ip=0805c07c ref=00000000
gf_dev_attach() failed with 2
Set DisplayStatus to 2
OnOff: process IPC event HWsample 225 HWvariant 111 FinalShutdown 0
pidin ar devf-generics: /usr/sbin/devf-generic -r -b9 -t4 -p400,32 -s0x0,128m,,,,,,5000,100 -D -a . HW 225
IOC reports wrong HW 225. We use f1 (/usr/sbin/devf-generic -r -b9 -t4 -p400,32 -s0x0,128m,,,,,,5000,100 -D -a )
SWDL: startUpdate HW index 241, variant 9411
OnOff: phase Scan metainfo
We have to erase the FPGA, init the FPGA persistence and delete the orphaned headers (if there are any).
OnOff: phase Erase
OnOff: Progress 000
dev_fd == 7
devctl returned 0
arrayinfo.unit_size 262144
calling devctl with erase struct:
status: 0
offset: 0x40000
limit: 0x40000
Set DisplayStatus to 4
devctl(7,-2146694912,xx,12,0) returned 0OnOff: Progress 100
CEmergencySwdlDevCtrl::continueAfterEraseFpgaInitial
SWDL: Stopping EFS driver!
result of running command stop_efs_driver.sh is 0
SWDL: Starting EFS driver (automount)!
ECC mode iresult of running command start_efs_driver.sh is 0
s disabled
(devf t1::f3s_table_find:252) fs0p2 corrupt U: 94
Set DisplayStatus to 6
/HBpersistence/SWDL not found!
CEmergencySwdlDevCtrl.cpp
ASSERTION failed
SWDL persistence is not available!
useDefaultValuesForInfo: MU
FPGA info header @SWDL V1@
FPGA info version 1
FPGA info variant 9411
FPGA info type Main Unit
FPGA info HW index 61
FPGA info region <noRegion>
FPGA info step 0
FPGA info HW index IT 0
FPGA info ignore region/variant 1
FPGA info loop 0
FPGA info repeat 0
FPGA info CRC 16c693eb
ECC mode result of running command start_efs_driver.sh is 0
is disabled
ASSERTION failed
/HBpersistence/SWDL/update.txt doesn't exist
Copy of /HBpersistence/SWDL/update.txt.backup to /HBpersistence/SWDL/update.txt failed
Don't use update.txt
SWDL: Mount from medium 3 (0)
OnOff: variant 9411
OnOff: DeviceName MU9411
Src: Medialauncher is running
Src: mount OK
SWDL: mount OK
SWDL: open metainfo /metainfo2.txt
SWDL: open finished (120048)
OnOff: FileAccess for continues!
OnOff: Current file access type: read
SWDL: read finished (120048, 0)
SWDL: parse metainfo
SWDL: check signature and variant failed
SWDL: contAfterMetainfoError
SWDL: Mount from medium 4 (1)
Src: mount failed. Retry once in 1 s
Src: mount failed (medium unavailable 2)
SWDL: mount failed
SWDL: Mount from medium 5 (2)
SWDL: mount failed
SWDL: Mount from medium 2 (3)
Delay mount internal drive 0 1
Src: mount from CD ... still waiting...
Оптика не светит.
flashit -a 0x00040000 -e 1000, заголовок стирает. но восстановление не запускает.
Help.
Что ей надо. ???
