Can anyone comment on this taken from @theed post as I stuck here:
With vag can pro you can set the umts values for the eu. There is a zdc file for the telephony gain settings. After that the unit will connect to umts 3g
Any comment is appreciated, specially concerning zdc file and where to get it as in Vag Can Pro I can´t see any suitable one
There is no VCP ZDC-file or something else, which is able to activate the EU 3G UMTS Modes with an US version of the Telit or AH6 phone modul in the MMI.
The US modules are unable to handle this frequencies and modes in EU. You have to change the phone hardware as descriped in this thread.
Tschako писал(а):There is no VCP ZDC-file or something else, which is able to activate the EU 3G UMTS Modes with an US version of the Telit or AH6 phone modul in the MMI.
Thanks for answer, Yes I undarstand that, just after change modem to eu version (its available at aliexpress) do You need to change smth in navi unit or just update eu firmware and upgrade telit part of it using user defined update or need to change anything with vagcanpro also?
Is it the same situation with Audi A4 B9 2017 MIB2 High NAR? Can't find any information about what lte module is install on NAR cars and how to change NAR LTE freguances on EU.
Thanks for any information!
Yes, totally the same situation. Depending the RF requirements, they use CINTERION Modules in both cases. Bur for NAR it is ALS6A-US and for the EU its ALS6A-EU.
You only can exchange the CINTERION RF Modules into the Harman Housing to bring it from US-EU LTE Modes. Otherwise only 2G works in EU.
No, the PN you note, is an RF TwoWay-Amplifier to support the SmartPhones in the Cars Hold/Charg Holder.
Nothing todo with the LTE EU-Compatibilty of the MIB Unit.
There is no PN for the embedded RF Module of the MIB units. VW / Audi doen´t support repair issues with parts.
You have to desolder the US Module and resolder an EU version of the Cinterion RF Modules inside. A critical soldering job, I think.
But first of all, you have to find EU versions on the market...
Вложение 4129743012_1112583107.jpg больше недоступно
I have found module ALS6A-E. Am I right, that I need only replace my ALS6A-US and it should work properly with LTE?
Price is 57 usd for try, that why I would like to be sure. Thanks!
