Prolem to connect unit to online
spinmar
Сообщение spinmar »
A question I have About Google icon in the monitor.
Even if Google Earth is working well I do not see tha icon of "Google 3G" in the bottom right corner of MMI.
Is it possibile to insert it?
paszczak
Сообщение paszczak »
spinmar писал(а):A question I have About Google icon in the monitor.
hi Spinmar
yes - I have gogle earth and other working services like fuel prices, weather etc
jjlucas76
Сообщение jjlucas76 »
spinmar could you share the scripts, please?
I'm trying to use sergeynik script but I cannot change the resolv.conf if I use the command "echo nameserver xxx.xxx.xxx.xxx > /mnt/efs-system/etc/resolv.conf" from run.sh.
Do I need to create another script and upload it to /mnt/efs-system/scripts and then using sergeynik run.sh just touch that file to run it?
Luca
spinmar
Сообщение spinmar »
@Paszczak: the services you are writing ( fuel prices, weather, etc...), are ok. Google earth and tmc online are working well.
I'm asking how to insert the Google icon in the bottom right corner of MMI display, where now I have the time.
@jjlucas76: you can download the file http://www.datafilehost.com/d/63f6b577
Maybe the trick is the value of channel 69.
Yesterday I compared my value with the value of a friend of mine who has unit 670 and then he has the Google icon.
Ma value of channel 69: 32783 (bit 0, 1, 2, 3, 15 setted);
My friend: 32776 (bit 3, 15 setted);
So I have bit 0, 1, 2 setted while my friend not.
How is the meaning of these bits?
Do I have to deselect them?
Thanks
jjlucas76
Many Thanks I'll try to get Google online first :) and then report back about the google icon in the corner.
My head has 767 installed.
paszczak
spinmar писал(а):@Paszczak: the services you are writing ( fuel prices, weather, etc...), are ok. Google earth and tmc online are working well.
Yesterday I compared my value with the value of a friend of mine who has unit 760 and then he has the Google icon.
Thanks
I have HW 670 (build in sim card) - my channel 69 has value 32783 - but before I had there value 15 then no traffic online menu.but before even value was 15 I had google icon also so I dont think so its related with this icon
what do u mean bit 0,1,2,3, 15 setted? in adaption I am able to set new value only do u mean long coding?
Spinmar - if u want I can scan my settings for you for compare - just let me know what we should to compare.
I am intresting in compare with yours cause my traffc online still doesnt works
spinmar
Сообщение spinmar »
This is a bad news :(
It means that the google icon is not related to the value of channel 69.
Probably only Sergey can help us
paszczak
spinmar писал(а):This is a bad news :(
spinmar
Сообщение spinmar »
paszczak писал(а):what do u mean bit 0,1,2,3, 15 setted?
They are related to the value of the channel.
Only Sergey knows exactly the meaning of each bit.
paszczak
spinmar писал(а):They are related to the value of the channel.
can you tell me yours bit setted? can you show me your screenshots? I dont know where shall I looking for - as I wrote in adaptation I am able to set value only
spinmar
Сообщение spinmar »
Maybe I'm not clear enough.
In adaptation 10 there are 255 channels and for each channel you can set a value.
You cannot set each bit but you can set only a value which you can image as composed by different bit.
So as sergey wrote, to set bit 15 means +32768.
Only few persons knows the meaning of each bit and Sergey is one of these.
I'd like to add Google icon to bottom right corner and I don't know how to do it.
paszczak
spinmar писал(а):Maybe I'm not clear enough.
ok clear but bu what mean in this case that u have setted bit 0,1,2,3 and 15? and your friend just bit 3?
so in case o your friend if set bit 3 in channel 69 means his value is 32776 - but why not 3+32768 so 32771?
how can you set in same time bit 0,1,2,3 and 15? sorry I really dont understand - but I really want to compare my settings with your or your friend for get traffic online finaly - hope you will help me :)
spinmar
Сообщение spinmar »
paszczak писал(а):ok clear but bu what mean in this case that u have setted bit 0,1,2,3 and 15? and your friend just bit 3?
I have bit 0,1,2,3,15 setted. This means value 32783.
My friend: bit 3, 15 setted. This means value 32776
paszczak писал(а): so in case o your friend if set bit 3 in channel 69 means his value is 32776 - but why not 3+32768 so 32771?
bit 3 means +8
bi 15 means +32768
paszczak писал(а): how can you set in same time bit 0,1,2,3 and 15?
It means set my value: 32783
paszczak
spinmar писал(а):I have bit 0,1,2,3,15 setted. This means value 32783.
bit 3 means +8
bi 15 means +32768
so whats possible value range for channel 69? 15 and then 32768 up to 32783? what was your original factory value there? 15?
I am asking about range cause I want to set diffrent values for solve my issue with traffic online
Hi Sergey
do u think my problem with traffic online is related with wrong value in channel 69?
jjlucas76
I have managed to get the head online. no google icon on the right bottom corner of the MMI, but everything else works as expected.
Big thanks to Sergey and Spinmar for the knowledge and for sharing.
@Spinmar have you managed to change the adapter speed to 100Mbit, not that it will make any difference in performance, as the bottleneck here is the 3G connection, but just curios if you did and how.
I am using:
-DLINK adapter DUB-E 100 ver B1 for USB -> LAN converter
-Vonets VAR11N as WISP client
-2 Ports USB adapter to duplicate the port of the AUDI USB Cable.
I had tried also the Gembird NIC-U1 as USB -> LAN converter but i snot recognised by the head.
spinmar
Сообщение spinmar »
Good!
Unfortunately the Google icon is not related to 69 channel.
Let's see if Sergey will tell us something.
spinmar
Сообщение spinmar »
Problem solved
jjlucas76
what was it?
jjlucas76
spinmar писал(а):Problem solved
How did you get the Google icon to work?
spinmar
Сообщение spinmar »
Hi jlukas the trick is in the submenu telephony of the hidden menu: you have to set Nad activation and nad operation mode.
Try it and magically Google icon will be shown.
Remember to restart mmi
