Yes it is the same results ...Ginny.kmv писал(а):И так тоже (((
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_11384A (0ms)
Entering CLI, type '?' or 'help' for help
=> flashit -a40000 -e 1000
Unknown command 'flashit' - try 'help'
=> flashit-a40000-e 1000
Unknown command 'flashit-a40000-e' - try 'help'
=> help
востановление поврежденных голов +/ damage head unit repair
Ginny.kmv почему то в персональных сообщениях у меня не работает пробел
, не мог ответить нормально.
К сожалению я не общался с 3ГП, помочь не смогу.
зыЖ м.б. проблема не в софте? Тупо отошел проводок в разъеме?
You have to sync the Baud rate of the keyboard and the main unit. Means for a 3GP Facelift the keyboard link speed is 19200 Bit/s.
The pre Facelift version 3G uses 9600 Bit/s serial speed. Best way: use a FL key panel as well.
Other solution: change the port speed of the main unit to 9600 Bit/s compatibility in the hidden menu or change the coding. Think its APK 14, but not shure.
[quote = Ginny.kmv; 576851] Well here, and now the question . The man wrote that 5 bits (it is not coded) And you propose to 2 bits, here and disagreements. Now check course the Of [/ QUOTE]
for Keep of the mint in: binary counting Begins with "0" (zero)
Means you have to code byte 14 for an older 9600Baud Panel as follows: 00000100
доброго времени суток. audi a8 4H 2010г. после неудачного обновления имею черный экран и отсутствие связи с MMI.
очень нужна ваша помощь
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09362A
(0ms)
=> boot 1c0000
starting image @801c0000 ...
Startup: PL_qnx_startup-sh7785_08362A, built 2008/09/02_07-53-12_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046a20
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_08493A) MMI3G Audi EMERGENCY SETUP 09283A
starting pci driver
*** init FPGA registers ***
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting atapi driver - setup device /dev/cam0
starting devc-pty
Path=0 - XILINX ATAPI
target=0 lun=0 CD-ROM(5) - FJ-TEN DVD-ROM DV-04FT1 Rev: 1423
Path=1 - XILINX ATAPI
target=1 lun=0 Direct-Access(0) - TOSHIBA MK6050GA Rev: TJ10
starting flash driver
starting SDCard driver
Path=0 -
target=0 lun=0 Direct-Access(0) - SD02G Rev: 6.0
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
49169 running /usr/bin/devg-NVTIRM
DMA is Disabled
dma disabled, interrupt thread priority = 100
49171 running /sbin/io-media-nvidia
49172 running /usr/sbin/io-display
49173 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
discplayer_init: IN
nvidia_render_manager_init: IN
INvmRenderManager::GetNvmRenderManager (&pRenderManager);
er = pRenderManager->Init(oConfig);
# App FPGA valid 1
Emergency FPGA valid 1
Disabling IOC watchdog
EmergencyApp-MMI3G: version 30.15.1812, date of build 08.07.2009
pRenderManager->Open()
nvidia_render_manager_init: OUT
discplayer_init: OUT
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
created navigator control point with 8249288
mixer_init: IN
mixer_init: OUT
NvTRACELEVEL set to 3 (Level Info)
nVAudio_init: IN
nvidia_render_manager_init();
nVAudio_init: OUT
installing audio decoders
installing video decoders
nVAudio_init: IN
nVAudio_init: OUT
OnIpcGetCaptureUnitSourceCount
Number of displays: 6
Number of layers: 9
Graphics init was successfull: DisplaySize is 800x 480
The FPGA for the application is valid!
Emergency application will do nothing!
result of running command start_efs_driver.sh is 0
HBpersistence is available!
** DeveloperMode is off!!!! **
** The system will shutdown soon! **
** DO NOT FLASH WITH SCRIPTS IN THIS MODE!!! **
** You can enable DeveloperMode like this: **
** echo dummy > /HBpersistence/DeveloperMode **
Set DisplayStatus to 2
Set DisplayStatus to 4
OnOff: process IPC event HWsample 209 HWvariant 111 FinalShutdown 0
Set DisplayStatus to 6
Enabling IOC watchdog
Initiate shutdown (after BEM timeout)...
OnOff: process IPC event HWsample 209 HWvariant 111 FinalShutdown 1
Confirm shutdown to IOC
(0ms)
=> boot 1c0000
starting pci driver
starting devc-pty
Path=0 -
the application.
DMA is Disabled
discplayer_init: IN
# App FPGA valid 1
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
mixer_init: IN
mixer_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
Number of layers: 9
