Hello Zerbino,I tried a script to make a backup from my actual FSC file but I can't to do it work. Is there a way to do a backup easyli ?Thank you
Чтож вы всё на блюдце хотите, сами вообще не напрягаясь? Всё вам дай да дай...
I suppose that you can use the code below as run.sh.
Insert this run.sh in the stardard format sdcard to execute command.
#!/bin/ksh
sdcard=`ls /mnt|grep sdcard.*t`
echo Using card $sdcard
dstPath=/mnt/$sdcard
mount -u $dstPath
$dstPath/utils/showScreen $dstPath/screens/scriptStart.png
echo started > $dstPath/.started
mount -uw /mnt/efs-persist
cp /mnt/efs-persist/FSC/* $dstPath/
$dstPath/utils/showScreen $dstPath/screens/scriptDone.png
echo done > $dstPath/.done
Thanks a lot Spinmar !! It worked !!!!
часто просят подредактировать апликейшен, а у меня нет времени
вот вам простой способ
ищете строку в HEX редакторе
Very often people ask to edit application , but i have no time .
This is easy way , just find string in HEX editor
A0 91 10 35 3A 8D 02 71 10 35 41 8D 83 64 DF A0 09 00 98 91 10 35 4E 8D 17 35
если эта строка встречается 1 раз, то меняете 2 байта(4E на 09 и 8D на 00)
if this string find only once then change 2 bytes (4E to 09 and 8D to 00)
A0 91 10 35 3A 8D 02 71 10 35 41 8D 83 64 DF A0 09 00 98 91 10 35 09 00 17 35
Последний раз редактировалось sergeynik; 14.05.2014 в 00:11.
Thanks your very much sergeynik :-) Does anyone know how to extract this "MMI3GApplication" from firmware CD ?
I think this is somewhere in "\MU9498\efs-system\41\default\efs-system.efs" or "\MU9498\efs-system\51\default\efs-system.efs"
Последний раз редактировалось iridium; 14.05.2014 в 10:39.
MMI3GApplication is in (in your case) \MU9498\ifs-root\41\default\ifs-root.ifs
You can extract it by several ways -
1. Install it to your MMI unit and using startdumper.sh copy it to efs and then to your sd
2. Extract it from ifs image ( ask somebody to do it )
P.S. the answers for your questions you can find on this forum
Thanks UkNik. I'm fighting with QNX Live CD with no success... And no script found to read MMI3GApp from MMI... As it's not findable on the net, I've uploaded last MMI 3GP US Firmware version K0715. If someone can extract this MMI3GApplication... :-)
https://mega.co.nz/#!PtQGkSqB!aH4YPH...Biq9-B4DFXiZ5Y
iridium Your app http://yadi.sk/d/X0H7j_MUQHecV
Thanks you very very much guys !!! This forum truly rocks !! :-))))
Last question: Do you know where "MMI3GApplication" is written ? On internal MMI Hard Disk or on EEPROM ?? Again, many many thanks !!
Ну вот я снова с онлайн и картами 2014 года, единственный нюанс, после активации некорректо повел себя gps, переустановил патч еще раз, вроде ситуация пришла в норму, но на первый взгляд карта работает не так плавно. Сергей я в свое время просил вас собрать ифс с правленным апп под 770 прошивку, может найдете время.
Please note: ifs-root.ifs doesn't live on the hard drive, it's on the flash of the MMI... you can unpack from firmware and repack as you wish.
I found my answer here:
http://www.scribd.com/doc/221492426/...ive-Partitions
Не все родное там восстановить не реально, воспользовался чужим и к дилеру на снятие СР. Вернулась моя старая лицензия от 30.11.2013 года, и потом только поставил карты 2014.
Последний раз редактировалось tvitek; 16.05.2014 в 10:38.
Ну супер, отличный вариант, вай бы нот, как грится. Я вот все жду когда мне дилер машин мою вернет, руки чешутся обновиться. Прошивку обновил, ошибки потер, а вот карты не успел.
Hello, if is something like this I agree to pay for, I have Google Earth working, wheater online but trafic online is not working.
Please help me
