MHI3 Activations ?
Показано с 1 по 7 из 7
Тема: MHI3 Activations ?
    Вопрос MHI3 Activations ?
    Hello guys. I am working around MHI3 activations. Some guys doing it remotely using Enet cable using Doip connection remotely. I am not sure which tool they are using. I have a software called Diagnose-Tool MIB3 published by Preh company. It has Can and TSS access option for MIB connection. CAN is being done by Pcan or Vector hardwares and TSS is being connected via D-Link car's usb port. I am not sure if it works for Swap activations because it says that in documentation, connection to company network is required for swap functions. I have tried to connect to MHI3 unit using this software but I dont know the IP address to connect using D-Link device. Does someone have any information about that software or know the IP address to connect MHI3 units?
    ​Here is the software I am talking about:
    Are there someone alive
    Serbia,Belgrade
    It is being done via gateway FOD hack.
    Stupid thing to do if car is in warranty,as it will create SVM problems.
    Serbia,Belgrade
    Also on MHI3/MPR3 units,access is closed.There is no password,all is done via challenge and response.
    Also your tool is not for MHI3/MPR3 it is MIB3OI with P(Preh) software trains letter at the end.
    UK
    Challenge - response or not, this was solved years ago.
    Its software component vulnerability and access can be unlocked ... w/o touching the unit
    Go figure
    Gateway use ip-address: 169.254.170.148
    IP address is in measurement value - IP4: $2ABB and IP6: $2ABC
    Port: 5555
    software:
    https://dl.google.com/android/reposi....3-windows.zip
    adb connect - Android ADB Shell Commands Manual
Метки этой темы
