делаю ресет.
и может загрузиться с таким логом.
closep
BIOS: No packet found!
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_13382A, built 2013/09/17_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09422A
(0ms)
*** emergency FPGA loaded!
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001a
starting image @1c0000 ...
Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046ae0
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_09423A) MMI3G Audi EMERGENCY SETUP 15325A
starting pci driver
*** init FPGA registers ***
[pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting atapi driver - setup device /dev/cam0
[pcidma] finished.
[pcidma] finished.
xpt_configure: No eide interfaces found
Unable to access "/dev/cam0" (2)
starting devc-pty
starting flash driver
starting SDCard driver
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
53265 running /usr/bin/devg-NVTIRM
DMA is Disabled
dma disabled, interrupt thread priority = 100
53267 running /sbin/io-media-nvidia
53268 running /usr/sbin/io-display
53269 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
discplayer_init: IN
nvidia_render_manager_init: IN
INvmRenderManager::GetNvmRenderManager (&pRenderManager);
er = pRenderManager->Init(oConfig);
# Fpga header is not 0x4744482e (0xffffffff)!
App FPGA valid 0
Emergency FPGA valid 1
Disabling IOC watchdog
EmergencyApp-MMI3G: version 37.26.2098, date of build 07.08.2015
pRenderManager->Open()
nvidia_render_manager_init: OUT
discplayer_init: OUT
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
created navigator control point with 8249288
mixer_init: IN
mixer_init: OUT
NvTRACELEVEL set to 3 (Level Info)
nVAudio_init: IN
nvidia_render_manager_init();
nVAudio_init: OUT
installing audio decoders
installing video decoders
nVAudio_init: IN
nVAudio_init: OUT
OnIpcGetCaptureUnitSourceCount
Number of displays: 6
Number of layers: 9
Graphics init was successfull: DisplaySize is 800x 480
Далее виснет.
и вот так.....
The FPGA for the application is valid!
Emergency application will do nothing!
result of running command start_efs_driver.sh is 0
Wait for HBpersistence...
