Hi Theed,
Did you find a solution or explanation for this ===DATA CHECKSUM ERROR === ?
Regards,
ROy
Hello, i can unpack IFS, change it and pack back. If you want know some more pelase write.
Так пиши прям сюда, не стесняйся. Тут все свои))
Ok so you must unpack ifs image with proper tool, find files structure in unpacked image, replace file which you want, pack image back with proper tool and change checksumsthats all
Can U explain what tool we need to unpack IFS?
What IFS file you need unpacked? Link?
for example this file :
https://mega.nz/#!vFdmATyB!tQeqMwxPo...4qb5B1z51WKNsI
Thank U very much mr bedrock.
Is there anybody who can repack IFS?
I need packed ifs to make repack![]()
Unpackign the ifs image is not a hard work.
With the help of mmi-ifs tool you can dump and decompress teh filesystem image. Than with dumpifs and with some shell scripting knoweledge you can extract and create the directory and file structure including the symlinks.
Maybe somebody can give some hints how to repack the filesystem structure into ifs image?
The mkifs utilitiy must be used? What arguments and attributes must be set for mmi3g?
Mistake, sorry
Последний раз редактировалось MMI; 04.01.2019 в 20:06.
Hello. I'm trying to dump IFS from MIB. ifs-root file have 22 509 852 bytes of size, unpacked files 15 882 984 bytes - why? How to make proper unpack?
Dumped ifs-root.ifs has two ifs images embedded in it like https://www.qnx.com/developers/docs/.../multiple.html
Need to find second ifs marker in dump and split, then extract both parts.
bedrock
Привет всем! Кто-нибудь может помочь выгрузить полностью файловую систему? В моем случае она двойная, dumpifs выгружает только одну. https://drive.google.com/open?id=151...8ox84c5XEXph17
