So far so good .....
Test unit info:
Код:
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_11384A (0ms)
Model 3G High 3908
SIM [no]
Main board version [9411/4010]
Source software HNav_EU_K0257_6_D1
New software HN+_EU_AU3G_K0942_3
Test results:
BT [works]
AMI BT [works]
Navigation [works]
Google earth/Street view/Online destinations [works with dlink]
Radio [works]
Media [works]
Car menu/communication [works]
DVD [not tested]
Diagnose [does not work]
WiFi [missing module]
If i find 3G high with SIM build ->2009 and some time i will test that too.
Useful E2P info:
Bytes responsible for internal telephone:
0x0000033f (831)
0x00000341 (833)
0x00000342 (834)
0x00000343 (835)
Bytes responsible for keyboard speed:
0x00000a84 (2 692) - control speed
0x00000a85 (2 693) - SWDL speed
Coding start address:
0x000000c8 (200)
CP info and some other stuff are widely discussed all over the place.
If someone knows other neat settings and their addresses please share
@Tschako - thanks for the dump, as i suspected i had wrong eeprom loaded and that's why my BT worked only as address book. With internal phone coded to off (addresses above) the BT works perfect.
I think that on unit with SIM if there is a problem with the module (as some say but dont share what is wrong) is we code it to turn off the module the unit will work on BT w/o issue.
While testing i also tested auto IOC reflash by creating proper update.txt in SWDL folder and it worked. Wonder if it will work if for some reason the unit always boot in bolo mode (erased V850).
I also started to debug if we can change the buttons id's so we can use the old 3G high keyboard and the buttons to be in the right order. But i think that this info is in the rom.classes file and i cant open that.
Other than wrong button id's the keyboard works just fine.
It will be great to combine force and make this complete ... if possible.
Regards,
Congo
