MMX restore - HELP
Показано с 1 по 20 из 25
Тема: MMX restore - HELP
    По умолчанию MMX restore - HELP
    i have errace MMX.
    Can i recording files eifs.img,mifs-stage1.img,mifs-stage2.img with command
    flashit -p /net/mmx/fs0 -a 0x160000 -d -f /net/mmx/fs/sda0/eifs.img
    flashit -p /net/mmx/fs0 -a 0x760000 -d -f /net/mmx/fs/sda0/mifs-stage1.img
    flashit -p /net/mmx/fs0 -a 0xA60000 -d -f /net/mmx/fs/sda0/mifs-stage2.img
    can I restore MMX this way?
    Последний раз редактировалось aleka; 06.05.2020 в 19:00.
    what hardware is needed to do this
    Any JTAG debugger, i use J-Link EDU https://www.segger.com/products/debu...ls/j-link-edu/
    Can i use mmx_fs0 to recover or i need to make a clone of another MMX?
    mmx_fs0 is enough.
    After device founding via JTAG you also need cut off BCT file from dump mmx_fs0 in 0 to 17EF adresses, then load this BCT file to MIB with help of TegraRCM https://github.com/NVIDIA/tegrarcm . It work via USB.
    https://turbo-quattro.com/showthread...l=1#post642033
    Последний раз редактировалось aleka; 06.05.2020 в 19:01.
    Thank you for help me ,
    I'm waiting for the hardware then I'll try
    How connect jtag to Technisat???
    What for?
    Could you share??
    Курск
    photo board?
    Yes please jtag no sd-card connection.
    Курск
    please photo your board Technisat
    ZR from PREH....the side??
    Курск
    please give me the files you read
    Последний раз редактировалось eprst; 15.05.2020 в 20:35.
    Курск
    you are welcome))
    Thanks a lot!!
    How setup j-link??
    Type of mcu??
    Курск
    MCIMX6D6AVT10AD
