Hello.
I have a problem,I buy a damaged unit.
No communication via obd and LAN and blue screen.
Now it doesn't accept any software from SD.
Can it be repaired somehow?
Unit 8V0035043
Hello.
Unit 8V0035043
Whats the original part-number and Firmware version?
HW: 8V0 035 043
SW: MHIG_US_AU_K2018 MU0406
Try put SD with that software in it.
Have you original part-number from firmware update?
8V0906961AA - MHIG_US_AU_K2018
Do you have tested it with this firmware? Put it to sd card slot 1 in mib system.
If it doesn't work you can test it with root Access with UART Adapter.
I think is a Problem in IFS file System.
I only have this firmware MHIG_US_AU_K2018 MU0406 but it doesn't work with SD.
Can you show me the connection to UART?
Until now, I have only repaired MMI 3G and 3GP
Today I bought another unit and it was damaged
https://rennlist.com/forums/991/1049794-porsche-pcm-upgrade-hack-for-android-auto-is-this-real-7.html#post16022781
can i have some hints I don't have experience with mib
[flashlock] Info : Root-Block at Offset (52)!
0 image type=1(IPL ) 0... 1ffff ( 131072)|0...1 (1):LOCKED
1 image type=2(IFS ) 20000... 3c6987 ( 3828104)|1...31 (30):LOCKED
2 image type=2(IFS ) 540000... b938b3 ( 6633652)|42...93 (51):LOCKED
3 image type=2(IFS ) ba0000...186bcab (13417644)|93...196 (103):LOCKED
4 image type=3(EFS ) 1d40000...353ffff (25165824)|234...426 (192):NOT LOCKED
5 image type=3(EFS ) 3bc0000...42bffff ( 7340032)|478...534 (56):NOT LOCKED
6 image type=4(DSP ) 3d00000...3dd6ac3 ( 879300)|488...495 (7):LOCKED
7 image type=5(BIOS) 3f00000...3f51cbf ( 335040)|504...507 (3):NOT LOCKED
result of running command flashlock is 0
/HBpersistence/SWDL/update.txt doesn't exist
startUpdate 1
Don't use update.txt
SWDL: Mount from medium 3 (0). ResetReleaseSearch 1
ERROR: /net/mmx/ramdisk/eassist doesn't exist
OnOff: DeviceName RCC
Display: Info1Text RCC
Failed to output Info1Text RCC
We assume production mode is not active
Display: Info3Text Try medium USB
Try medium USB
Failed to output Info3Text Try medium USB
SWDL: mount failed (1)
BREAK detected - press any key to stop the ipl within 5000ms! => BREAK accepted!
closep
IPL: A052 (C3 sample) ver.12254A [built 2012-06-21 17:15:45 2515472+]
CPU: rev.0x4, 600/570/400 MHz (ARM/DSP/DDR)
RAM: 128 MB
Flash: 64 MB (GL-S type)
*** UNHANDLED SPI event(s): 8/c [num=0]
IOC boot mode: ** ERROR #-1!
*** WARNING: no IOC boot mode, assuming 'N3'!
Entering CLI [?], type '?' for help
i can pay for quick help.
Pisz priv albo dzwoń 696 669 346
NaviTronic- już ogarnięte...
Is unit in EFU mode?
You need sd card with update.dat files.
