A6, A7 MHI2_ER_AU57x_P3634 or P3236 Hash - Страница 2
Показано с 21 по 27 из 27
  1. #21
    Of course I use it in my car for one month
  2. #22
    Цитата Сообщение от Lapkritinis Посмотреть сообщение
    Is it safe to update from AU57x from 2519 to 3663? If I just want newer version?
    It works, but there is fault code. Can anyone give hint how to fix?
    Код:
    Address 5F: Information Electr. (J794)      Labels:* None
      Part No SW: 4G1 035 021 N    HW: 4G1 035 021 D
      Component: MU-H-LND-EU  051 1425
      Serial number:
      Coding: 017562010000000013111102000A00132F0008E5F17001009F
      Shop #: WSC 02391 785 00200
      ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
      ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
      VCID: 2514FB37056F1DAF9A1-8070
      Data medium:
      Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
      Component: ECE 2018/2019  --- 0169
      Serial number: --------------------
      Display unit 1 for multimedia system:
      Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
      Component: DU8 C7 SV  H63 0007
      Serial number:
      Multimedia Operating Unit:
      Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
      Component: E380 BDT C7  H20 0250
      Serial number:
      Compact Disc Database:
      Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
      Component: Gracenote2  --- 1017
    1 Fault Found:
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
              Confirmed - Tested Since Memory Clear
                Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 137
                        Mileage: 40878 km
                        Date: 2019.12.03
                        Time: 20:26:17
                        Voltage terminal 30: 14.9 V
                        Software module: status-SW_Status_Consistency: 00 28 13
                        Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
  3. #23
    EU
    After firmware update to 3634 on my A7 i have error 1555- Check software version management. Please help with clearing of this error. I have VCP and VCDS. Thank s
  4. #24
    Adaption: IDE02502 - Confirmation of installation change value XOR C9D2, enter new value separated with space.
  5. #25
    EU
    Works! Thank U!!!
  6. #26
    EU
    Hy! After firmware update to 3634 on Audi A6 I have error
    Confirmed - Tested Since Memory Clear”
  7. #27
    France
    Hi,
    Im' running S2519 and would also like to update to P3634 as it seems to be the first step to go. Anyone can share this one ? and any new one after this one will be installed ?
    Regarding the error after upgrade, (1556), can it be fixed the same way as the 3663 mentioned earlier with adaptation ?
    Thanks
