Audi A7 4G MIB
Показано с 1 по 14 из 14
Тема: Audi A7 4G MIB
    По умолчанию Audi A7 4G MIB
    Добрый день!
    Пропал street view, прошивка (MHI2_ER_AU57x_K2570) 4M0906961Q, что могло произойти и есть ли новая прошивка? Если можно номер. Спасибо
    You wont get street view with new software.
    VW group does not offer
    street view anymore ... but that does not mean that it cannot be made to work
    Thank you!
    I did't use it. I thought maybe api changed and I need to update the system
    Can you tell what is the current version and its number?
    Latest known is MHI2_ER_AU57x_P3634
    Sorry, can you provide part number for A7?
    not available, this is factory only software.
    If they release one for dealers then should be MHI2_ER_AU57x_Kxxxx
    Thank you. So I have the latest official version of the software.
    Does anyone have the login password for root acces on MHI2_ER_AU57x_P3634? I also have this version and since there is no update there is no chance to get a firmware file....
    If there is no firmware file U need to read eMMC flash and serach for password hash. Then U need to find someone who can crack it for U.
    mobista,
    many thanks for your replay! Is there any documentation about connection to the eMMC flash and to read out its contents?
    U need to disassemble unit and check flash chip version - it should be BGA100 eMMC chip. U need to desolder this chip and can read with cheap SD card USB Reader or better solution is to buy BGA100 socket eMMC USB reader. When the chip will be out of mobo good move should be making of ISP pinout for next time chip reading without desoldering. After backup made U need to search for password hash and crack it with known tools.
    Hi guys,
    somebody can support us with the FW Train MHI2_ER_AU57x_P3634 for the MIB2???
    Thanks and Regards
    Tschako
    root password is not important at all.
    It could be easily bypass if you had any earlier version firmware for the unit.
    @jvkk:
    How to get an earlier firmware? Do you have it?
