Why if I try in run.sh to copy MMI3GApplication I don't get nothing in sd?
The command is:
cp /mnt/ifs-root/usr/apps/MMI3GApplication $SDPath/MMI3GApplication_from_user_apps
Thanks
The command is:
Thanks
Последний раз редактировалось eprst; 26.04.2014 в 12:27.
Try to put the command in startDumper.sh
1. Copy startDumper on card: cp /mnt/efs-system/usr/bin/startDumper.sh $SDPath/
2. Edit startDumper, add line cp /mnt/ifs-root/usr/apps/MMI3GApplication $SDPath/MMI3GApplication_from_user_apps
3. Copy startDumper in MMI
4. Reboot MMI with the card inserted without any script
5. Copy in MMI the original startDumper
Thanks.
Is the sd mounted when startdumper.sh is executed?
When is startdumper executed?
At the startup?
It may be a card is not yet installed.
I do not know exactly. Can try to copy to /mnt/efs-system/ under a different name, and then copy to the card.
startdumper.sh is executed by one of the first
I can't undestand one thing.
Probably someone can explain me.
This is the content of directory /usr/apps:
If I try to print the content of /mnt/ifs-root/usr/apps/ I get:/usr/apps:
total 9
lrwxrwxrwx 1 root root 39 Jan 01 00:03 MMI3GApplication -> /mnt/ifs-root/usr/apps/MMI3GApplication
lrwxrwxrwx 1 root root 33 Jan 01 00:03 MMI3GMedia -> /mnt/ifs-root/usr/apps/MMI3GMedia
lrwxrwxrwx 1 root root 32 Jan 01 00:03 MMI3GMisc -> /mnt/ifs-root/usr/apps/MMI3GMisc
lrwxrwxrwx 1 root root 38 Jan 01 00:03 MMI3GNavigation -> /mnt/ifs-root/usr/apps/MMI3GNavigation
lrwxrwxrwx 1 root root 37 Jan 01 00:03 MMI3GTelephone -> /mnt/ifs-root/usr/apps/MMI3GTelephone
lrwxrwxrwx 1 root root 51 Jan 01 00:03 MMI3G_MapArchive.xar -> /mnt/nav/map/styles/01/MMI3G_MapArchive_H_06_01.xar
lrwxrwxrwx 1 root root 30 Jan 01 00:03 NavCore -> /mnt/ifs-root/usr/apps/NavCore
dr-xr-xr-x 2 root root 0 Jan 01 00:03 bench
lrwxrwxrwx 1 root root 30 Jan 01 00:03 dev-irc -> /mnt/ifs-root/usr/apps/dev-irc
lrwxrwxrwx 1 root root 36 Jan 01 00:03 diagnosis.cfg -> /mnt/ifs-root/usr/apps/diagnosis.cfg
Why?/mnt/ifs-root/usr/apps:
total 729
drwxrwxrwx 2 root root 0 Jan 01 00:00 bench
-rwxrwxrwx 1 root root 372917 Jan 01 00:00 diagnosis.cfg
MMI 3G+ c картами 2013 года - тоже не работает это решение
пользоваться не умеете, вам путь к тому кто умеет
Прям как в анекдоте-вы любите кошек-вы их просто готовить не умеете
Толкните в нужное направление, я способный
Я может конечно не прав, но вроде уже все разжевано и максимально автоматизированно. В чем вопрос то конекретно, или что значит - "не работает решение"?
получается так, что модифицированный mmi3gaplication у меня не прописывается или путь к нему, пробовал 2-мя способами которые нашел тут (для vw и для ауди) в итоге я имею 3 активные лицензии 40003, 40405 и 40007, но карты не разблокированы и вин виден, т.е скрипт не отработал или еще что...
еще раз повторю - MMI3GP версия прошивы 770, карты пробовал и 14 год и 13
вычитал свой твоим скриптом http://turbo-quattro.com/showthread....l=1#post345067 - 6 пост, мой отличается на 2 байта от варианта Сергейника и чуть больше от варианта харвин3
Последний раз редактировалось eprst; 29.04.2014 в 19:49.
1. удали апп из /mnt/efs-persist
2. Перезапусти голову.
3. Посмотри, появился ли апп в /mnt/efs-persist
Если появился - замени в /mnt/persist апп на пропатченый. Если не появился startdumper и ртфм вначале темы, что и как.
количество лицензий у меня увеличивается и появилась одна "не верная"
таким способом удалю лицензии?
#!/bin/ksh
sdcard=`ls /mnt|grep sdcard.*t`
echo Using card $sdcard
dstPath=/mnt/$sdcard
mount -u $dstPath
echo remounted for full access
$dstPath/utils/showScreen $dstPath/screens/scriptStart.png
rm -f $dstPath/.done
echo started > $dstPath/.started
# Удаление лицензий
mount -uw /mnt/efs-persist
rm -R /mnt/efs-persist/FSC/*
$dstPath/utils/showScreen $dstPath/screens/scriptDone.png
echo done > $dstPath/.done
rm -f $dstPath/.started
Последний раз редактировалось eprst; 30.04.2014 в 17:25.
Sergeynik, ты говорил, что путём нехитрой правки меты, можно рнсным ключем сделать таблетку для ауде. И что-то всё "знающий человек" не сделает это. Вы забили, забыли, или передумали? Всё таки аудифилов порадовать было бы не плохо
во первых это было сделано, корбофос выкладывал меты
во вторых тут и аудевый ключ выкладывали
пробовал и с мета2 (вставлял в карты перед заливкой) для VW и ключ для 3GP - не работает ни то ни то, лицензий валом - толку - ноль,
вот этим http://yadi.sk/d/auJ0jeixJp2uq - вытащил свой MMI3GApplication, сравнил его с этим http://www.sergeynik.com/mmi/MMI3GAp...61dg_K0770.rar - разница 2 байта - вроде то что надо,
скачал http://www.sergeynik.com/mmi/MMI3GApp_path_change.rar, вставил в папку SERGEYNIK/efs-persist/ - MMI3GApplication и папку с ключем ( пробовал и ключ 40007 и для VW - 40405 )
пс - перед записью карт (версия для VW) мету менял в карте
- итог -
1) ключи записал и они активны ( после игр с ключами еще один и не активный появился.. ) (про удаление спросил выше - ни кто не ответил пока)
2) ВИН по прежнему виден
3) через 3 минуты - ДАННЫЕ НАВИГАЦИИ НЕ ДОСТУПНЫ
ну так что не верно я сделал?
