востановление поврежденных голов +/ damage head unit repair - Страница 41
Страница 41 из 46 ПерваяПервая ... 313940414243 ... ПоследняяПоследняя
Показано с 801 по 820 из 918
  1. #801
    Ростов-на-Дону
    делаю ресет.
    и может загрузиться с таким логом.
    closep
    BIOS: No packet found!
    IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_13382A, built 2013/09/17_15-16-25_UTC]
    CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
    RAM: 512 MB (probed, DBCONF=e30002)
    FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
    FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09422A
    (0ms)
    *** emergency FPGA loaded!
    *** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001a
    starting image @1c0000 ...
    Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
    RAM : 128 MB @0x08000000
    RAM : 128 MB @0x40000000
    RAM : 256 MB @0x50000000
    FLASH: 128 MB @0x00000000
    FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
    System page at phys:0800a000 user:0800a000 kern:8800a000
    Starting next program at v88046ae0
    Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_09423A) MMI3G Audi EMERGENCY SETUP 15325A
    starting pci driver
    *** init FPGA registers ***
    [pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
    starting dev-ipc for IOC
    initialize IPC Driver
    starting network driver
    starting atapi driver - setup device /dev/cam0
    [pcidma] finished.
    [pcidma] finished.
    xpt_configure: No eide interfaces found
    Unable to access "/dev/cam0" (2)
    starting devc-pty
    starting flash driver
    starting SDCard driver
    Unable to access "/dev/io-net/en5" (2)
    starting with no network driver
    Emergency IFS is started. Emergency app tries to restore
    the application.
    53265 running /usr/bin/devg-NVTIRM
    DMA is Disabled
    dma disabled, interrupt thread priority = 100
    53267 running /sbin/io-media-nvidia
    53268 running /usr/sbin/io-display
    53269 running /usr/apps/MMI3GEmergencyApp
    Emergency shell started, fix your system and restart again
    discplayer_init: IN
    nvidia_render_manager_init: IN
    INvmRenderManager::GetNvmRenderManager (&pRenderManager);
    er = pRenderManager->Init(oConfig);
    # Fpga header is not 0x4744482e (0xffffffff)!
    App FPGA valid 0
    Emergency FPGA valid 1
    Disabling IOC watchdog
    EmergencyApp-MMI3G: version 37.26.2098, date of build 07.08.2015
    pRenderManager->Open()
    nvidia_render_manager_init: OUT
    discplayer_init: OUT
    discplayer_init
    discplayer_init: IN
    dvdtrackplayer_init
    discplayer_init: IN
    dvdnavigator_init
    created navigator control point with 8249288
    mixer_init: IN
    mixer_init: OUT
    NvTRACELEVEL set to 3 (Level Info)
    nVAudio_init: IN
    nvidia_render_manager_init();
    nVAudio_init: OUT
    installing audio decoders
    installing video decoders
    nVAudio_init: IN
    nVAudio_init: OUT
    OnIpcGetCaptureUnitSourceCount
    Number of displays: 6
    Number of layers: 9
    Graphics init was successfull: DisplaySize is 800x 480
    Далее виснет.
    и вот так.....
    The FPGA for the application is valid!
    Emergency application will do nothing!
    result of running command start_efs_driver.sh is 0
    Wait for HBpersistence...
    Последний раз редактировалось Clark; 13.09.2020 в 10:06.
  2. #802
    Ростов-на-Дону
    Как прошить MOST в консоли ?
  3. #803
    Ростов-на-Дону
    По умолчанию mmi . help
    most_свет_680000_ful.txt
    boot 1c0000.txt
    После долгих экспериментов.
    оптика светит. при полном программировании флэшь.
    какое железо битое ? HELP.
    boot 1c0000 виснет.
    Чего он ждёт ? Что не даёт ответ ?
  4. #804
    Ростов-на-Дону
    Log. start.
    на что ругается ??
    Вложения Вложения
    • Тип файла: txt log.txt (32.9 Кб, Просмотров: 12)
  5. #805
    Warszawą
    friends i have problem mmi 3g 3gp software loaded i got my cards wrong and now i have black screen problem
    IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
    (0ms)
    *** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001e
    Startup: PL_qnx_startup-sh7785_08362A, built 2008/09/02_07-53-12_UTC
    RAM : 256 MB @0x08000000
    Starting next program at v88046840
    Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_08124A) MMI3G Audi EMERGENCY SETUP 9308 D1 09431A
    starting pci driver
    Unable to access "/dev/sysregs" (2)
    Can't start driver '/dev/ipc/onoff'starting network driver
    starting devc-pty
    the application.
    69644 running /usr/bin/devg-NVTIRM
    DMA is Disabled
    69646 running /sbin/io-media-nvidia
    69647 running /usr/sbin/io-display
    69648 running /usr/apps/MMI3GEmergencyApp
    discplayer_init: IN
    App FPGA valid 0
    COnOffIPC.cpp:41: ASSERTION failed
    COnOffIPC.cpp:76: ASSERTION failed
    EmergencyApp-MMI3G: version 22.30.2098, date of build 14.10.2009
    discplayer_init
    discplayer_init: IN
    dvdtrackplayer_init
    discplayer_init: IN
    dvdnavigator_init
    mixer_init: IN
    mixer_init: OUT
    nVAudio_init: IN
    nVAudio_init: OUT
    nVAudio_init: IN
    nVAudio_init: OUT
    Number of layers: 9
  6. #806
    Chile
    Поменял NOR RCC и микросхему MMX, могу подключить блок, у меня RCC и MMX, плюс не работают примечания MENU и HOME
  7. #807
    подскажите Audi Q7 магнитола не включается после того как постоит машина только через 3 кнопки сброса, прошивку через флешку обновляли до B-BBT_EU_K0029_1_D1, повторно прошить не получается через SWDL в зеленке все активировано для ручного выбора прошивки галки не дает поставить
  8. #808
    лог в терминале до прошивки
    Starting next program at v8804aa20
    Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3G Build D1 9302 D1-10284A
    s: 0
    v: 0
    r: 0
    m: 0
    mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/efs_symlinks.cfg
    done
    s: 0
    v: 0
    r: 0
    m: 0
    mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/ifs-root_symlinks.cfg
    done
    starting server starter...
    # multicored [000000001.358]:version 4.1.d, verbosity 1 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL
    multicored [000000001.745]:udp: broadcaster created
    multicored [000000001.781]:attached to filesystem at /hbsystem/multicore, port 851
    multicored [000000001.871]:MACHINE:SH(1), total MEM 235929600, 1: 271582976 SH7785 (SH4A) 594MHz, FPU
    multicored [000000001.885]:sloop active
    multicored [000000001.886]:lo0 127.0.0.1 255.0.0.0
    multicored [000000001.997]:listener on port 851 active, fd=7
    dev-nvram: PL_qnx_dev-nvram_07225A, built 2007/06/01_15-44-08_UTC
    dev-nvram: page_size:4096
    dev-nvram: signalling register 10ee:9302:0:40:40 [vid:did:barffs:mask]
    dev-nvram: CPU: SH7785 (5th cut or higher, clk_mode 16) [10300700:250, 122524f8]
    dev-nvram: map '/dev/nvram/navi' to 0x16100000-0x17cfefff
    dev-nvram: map '/dev/nvram/.guard' to 0x17cff000-0x17cfffff
    dev-nvram: SelfRefresh was inactive
    UART: Mod:0E Date:08511A Ver:2.2.1
    devc-ser8250hb: UART supports FiFo counter
    devc-ser8250hb: UART supports 32bit access
    devc-ser8250hb: RX_FIFO_SIZE:512 TX_FIFO_SIZE:512
    devc-ser8250hb: set IBUF size to 4096
    devc-ser8250hb: RX_FIFO_SIZE:32 TX_FIFO_SIZE:32
    JVMEXEL085W
    WARNING: The command line argument "-jxe:" has been deprecated.
    WARNING: Use "-jxe <path>" instead.
    DSIVersion: 0.0.0
    DSISource: DSI 2009_49_49
    DSI-Build-Version: 30.11.09/v1.138.3
    ReleaseLabel: Integration_AU_MMI3G_10101P
    Path=0 - QSSL SERCD
    target=0 lun=0 CD-ROM(5) - Philips CDM-M8 Rev: 45N
    start JDSI bundle
    jdsi.loglevel : 2
    No External Component found
    stream factory memory mode : classic
    dsigen v1.138.3 - core v2.1
    prop os.arch : sh4
    prop jdsi.3SoftOSGi : true
    DSI dispatcher disabled!
    cd0 mounted after 1 try
    [MSG]@5903 (86047.161): COnOffPresCtrl::requestSetPowerState(), state: 3
    [MSG]@6177 (86047.161): COnOffPresCtrl: IOCBoloMode: 0
    [MSG]@6178 (86047.161): -- getHardwareSample: state=2 -- hwSample = 0xd1
    [MSG]@6179 (86047.161): -- getHardwareVariant: state=2 -- hwVariant = 0x2
    [MSG]@6179 (86047.161): COnOffPresCtrl: newSystemState: 20
    [MSG]@6209 (86047.161): +++ PRODUCTION_MODE is 0
    [MSG]@6213 (86047.161): +++ remounting of the efs partitions is done, persistency is set to fully operable...
    [MSG]@6223 (86047.161): +++ TEL_SETTINGS_REST is 3
    [MSG]@6224 (86047.161): +++ setting BtAvailable to true
    [MSG]@6232 (86047.161): +++ ReadInt FLAG_SYSTEM_RESET, Value 0
    [MSG]@6233 (86047.161): +++ normal shutdown detected, save ON as FLAG_SYSTEM_RESET
    [MSG]@6241 (86047.161): +++ MISC_HB_REGIONCODE 0
    msgpassing channel opened on /dev/dsi/data
    NAVI: sys_alloc_shm_area(/dev/nvram/navi) open() ok: 31
    NAVI: sys_alloc_shm_area(/dev/nvram/navi) filesize() = 29356032
    NAVI: sys_alloc_shm_area(/dev/nvram/navi) mmap to 50000000
    DSIAddressbook (0) - v10.0G1.138.3
    DSIAddressbook (1) - v10.0G1.138.3
    DSIAddressbook (2) - v10.0G1.138.3
    DSIAddressbook (3) - v10.0G1.138.3
    DSIAMFMTuner (0) - v8.0G1.138.3
    DSIAudioManagement (0) - v8.1G1.138.3
    DSIBluetooth (0) - v4.3G1.138.3
    DSIBrowser (0) - v4.0G1.138.3
    DSIBrowser (1) - v4.0G1.138.3
    DSIBrowser (2) - v4.0G1.138.3
    DSICallLists (0) - v3.0G1.138.3
    DSICarClimate (0) - v4.0G1.138.3
    DSICarComfort (0) - v3.0G1.138.3
    DSICarParkingSystem (0) - v2.4G1.138.3
    DSICarSuspensionControl (0) - v1.0G1.138.3
    DSICarLight (0) - v2.0G1.138.3
    DSICarService (0) - v3.2G1.138.3
    DSICarDriverAssistance (0) - v2.0G1.138.3
    DSICarKombi (0) - v4.4G1.138.3
    DSIDABTuner (0) - v5.3G1.138.3
    DSIDiagHMIAttribs (0) - v4.0G1.138.3
    DSIIconrenderer (0) - v1.0G1.138.3
    DSIIconrenderer (1) - v1.0G1.138.3
    DSIDataDisplay (0) - v5.0G1.138.3
    DSIDisplayManagement (0) - v9.6G1.138.3
    DSIInfotainmentRecorder (0) - v2.0G1.138.3
    DSIKeyPanel (0) - v2.3G1.138.3
    DSIMapViewer (0) - v18.3G1.138.3
    DSIMedia (0) - v4.6G1.138.3
    DSIMediaRecorder (0) - v1.4G1.138.3
    DSIMOSTInfo (0) - v3.0G1.138.3
    DSINavigation (0) - v72.0G1.138.3
    DSIObexAuthentication (0) - v1.0G1.138.3
    DSIPhonoConv (0) - v1.0G1.138.3
    DSIPersistence (0) - v10.1G1.138.3
    DSIPowerManagement (0) - v3.4G1.138.3
    DSIStartup (0) - v1.2G1.138.3
    DSIProfileManager (0) - v6.0G1.138.3
    DSISDARSTuner (0) - v2.2G1.138.3
    DSISMS (0) - v4.1G1.138.3
    DSISound (0) - v8.0G1.138.3
    DSISSS (0) - v6.2G1.138.3
    DSISwdlDeviceInfo (0) - v1.1G1.138.3
    DSISwdlLogging (0) - v1.1G1.138.3
    DSISwdlProgress (0) - v1.2G1.138.3
    DSISwdlSelection (0) - v2.7G1.138.3
    DSITelephone (0) - v10.0G1.138.3
    DSITIMTuner (0) - v2.3G1.138.3
    DSITmc (0) - v9.2G1.138.3
    DSITmcOnRoute (0) - v6.0G1.138.3
    DSITTS (0) - v4.0G1.138.3
    DSITTS (1) - v4.0G1.138.3
    DSITunerAnnouncement (0) - v1.0G1.138.3
    DSITVTuner (0) - v5.2G1.138.3
    DSIVCardExchange (0) - v5.0G1.138.3
    DSIWavePlayer (0) - v5.2G1.138.3
    DSIWavePlayer (1) - v5.2G1.138.3
    Duration of starting JDSIBundle : 2571ms
    [MSG]@7096 (86047.161): +++ persistency StartupMode is 1
    decoder thread priority : 2000:0 (5)
    decoder thread priority : 100:0 (5)
    CHBComponentMux.cpp:317: ASSERTION failed
    CHBComponentMux.cpp:275: ASSERTION failed
    decoder thread priority : 12:0 (5)
    [MSG]@7389 (86047.161): +++ HW index: d1 variant: 9302
    [MSG]@7409 (86047.161): +++ MISC_HB_REGIONCODE 0
    decoder thread priority : 9:0 (5)
    AS: 2
    decoder thread priority : 4:0 (5)
    CPS: 3
    AS: 2
    decoder thread priority : 50:0 (5)
    decoder thread priority : 24:0 (5)
    decoder thread priority : 51:0 (5)
    decoder thread priority : 8:0 (9)
    dev-adjmanager: PL_qnx_dev-adjmanager_08182A, built 2008/04/29_12-08-24_UTC
    dev-irc: error in devctl errno=2 errCode=5
    Performing select():
    *** Jul 15 2010 / 11:28:56 ***
    [MSG]@11329 (86047.161): +++ HW index: d1 variant: 9302
    [MSG]@11337 (86047.161): +++ MISC_HB_REGIONCODE 0
    Path=0 -
    target=0 lun=0 Direct-Access(0) - 00000 Rev: 1.0
    decoder thread priority : 55:0 (5)
    decoder thread priority : 7:0 (5)
    [MSG]@13331 (86047.161): COnOffPresCtrl: newSystemState: 36
    [MSG]@13337 (86047.161): COnOffPresCtrl: newSystemState: 23
    [MSG]@13341 (86047.161): COnOffPresCtrl::requestSetPowerState(), state: 3
    [MSG]@13385 (86047.161): +++ successfull writing FLAG_SYSTEM_RESET
    decoder thread priority : 32:0 (5)
    MediaLauncher: [27 bytes]: ADD_SDC_MSD_/mnt/sdcard10
    decoder thread priority : 20:0 (5)
    Audi-2D native library version: 20081127
    Audi-2D java library version: 20081127
    Using HB FPGA driver
    [MSG]@15864 (86047.161): COnOffPresCtrl:rocessMMEEvent responsePersistenceDone
    [ERR]@15865 (86047.161): [COnOffPresCtrl] deletionfalg will not being deleted, because backuping the database wasnt successful
    [MSG]@23400 (86047.161): COnOffFSMHandler: persistence has been stored
    [MSG]@23520 (86047.161): +++ persistency StartupMode is 0
    [MSG]@23522 (86047.161): COnOffPresCtrl::requestSetPowerState(), state: 0
    CPS: 0
    AS: 2
    decoder thread priority : 30:0 (5)
    decoder thread priority : 31:0 (5)
    decoder thread priority : 33:0 (5)
    decoder thread priority : 52:0 (5)
    decoder thread priority : 53:0 (5)
    [MSG]@26961 (86047.161): +++ HW index: d1 variant: 9302
    [MSG]@26970 (86047.161): +++ MISC_HB_REGIONCODE 0
    ### Jul 15 2010 / 11:28:56 ###
    decoder thread priority : 28:0 (5)
    decoder thread priority : 18:0 (5)
    decoder thread priority : 26:0 (5)
    [MSG]@28943 (86047.161): COnOffPresCtrl: newSystemState: 14
    [MSG]@28971 (86047.161): +++ HW index: d1 variant: 9302
    [MSG]@28977 (86047.161): +++ MISC_HB_REGIONCODE 0
    [MSG]@28986 (86047.161): +++ MISC_HB_REGIONCODE 0
    [MSG]@30682 (86047.161): COnOffPresCtrl: newSystemState: 10
    slay: Unable to find process 'checkPersistence'
    EJECTHANDLER: shutting down ...
    EJECTHANDLER: getLoaderInfo_result: No error, getLoaderStatus: DISC_LOADED
    EJECTHANDLER: stoppedstart SSSProcess -> Config File: "/mnt/sss/general/default.cfg"
    --> SAM is running.
  9. #809
    Moskow
    Подскажите по поднятию головы,
    Изначально голова была
    MMI 3g+ от A8
    Потом она была перепрошита в Q7, на прошивке свалилась, выключился экран и больше не поднялась
    Сейчас при старте залетает в красное окно.
    Перепробывал разные прошивки никакую не принимает
    любая прошивка от ку7 дает ошибку
    Metainfo CRC error
    Тогда вылезает следующая ошибка
    MU9498(<noRegion>)
    Starting up
    Consistency error
    Update failed! Retry after reset
    если в файле metainfo поставить игнорировать CRC
    Пробывал в прошивке от A8 в фале metainfo менять вариант 9411 на 9498
    отключить проверку CRC в файле metainfo
    Но прошивка восстановление всеравно не начинается, выдает ошибку variant error!
    в прошивке нашел такой файл
    MUConsistency\Data\0\default\MainUnit-version2.txt
    пробовал копировать этот файл из прошивки от а8 в прошивку ку7, чтобы проскочить ошибку Consistency error, но успехом не увенчалось
  10. #810
    Moskow
    MMI 3g+ от A8
    Заставил, Я, головузапустить аварийное восстановление, путем редактирования metainfo
    Восставновление прошло успешно.
    По логу голова стартанула, но экран черный
    Куда дальше копать ? может как то заставить запустить обновление ?
  11. #811
    Ростов-на-Дону
    Ifs em mini, у кого есть ???
  12. #812
    Moskow
    Нету шаристых ?
  13. #813
    Привет всем. Я вынужден был установить прошивку ЕС на устройство США, изменив InstallationManager. Я хочу вернуться в США, но SWDL не работает. Могу ли я прошить свою резервную копию rcc_fs0 на чип rcc через telnet? У меня еще активен телнет через шпатлевку. какая-нибудь команда flashit для меня? Блок - Delphi MHS2 Audi.
  14. #814
    Rns850 есть у кого то мини ifs чтоб учспеть передать через zmodem ?
  15. #815
    Пользователь Аватар для dec123ua
    Киев
    Дима, через JTAG передай...
  16. #816
    Ростов-на-Дону
    Подскажите пожалуйста.
    нужная полная информация о боковом разъёме.
    какая Ламель куда приходит . Обозначение. Данные. И т.д.
    JTAG. UART . На форуме нашёл.
  17. #817
    Всем привет, товарищ решил перепрошить рнс850 с US на EU и после обновления она не включилась, подключился через терминал начал лить 711 usa прошивку, на зеленом экране появляется 7/8 Update succeeded restarting soon ... и после перезагрузки остаточное изображение от зеленого экрана и тухнет, а в терминале заканчивается вот так:
    [>>> parkHDD <<<]
    [>>> cleanup_navi <<<]
    cleanup navi done
    waiting for usbserial
    srvstarter info: Checking interface /dev/flexgps failed! No such device or addr ess
    [t(p) ./MMI3GTelephone 270389 43 10 7847095c]
    parkHDD done
    [WRN]@29876 (118808.10): devctl '0X40300552' <DCMD_HB_HDDMGR_GETTEMP> call faile d(errCode = 9 <Bad file descriptor>)
    EJECTHANDLER: getLoaderInfo_result: No error, getLoaderStatus: NO_DISC
    [WRNEJECTHANDLER: stopped]@30009 (118808.10): devctl '0X40300552' <DCMD_HB_HDDMG R_GETTEMP> call failed(errCode = 9 <Bad file descriptor>)
    [WRN]@30059 (118808.10): devctl '0X40300552' <DCMD_HB_HDDMGR_GETTEMP> call faile d(errCode = 9 <Bad file descriptor>)
    [WRN]@30068 (118808.10): Try to fix connection...
    checkPersistence - after 30 seconds: partition not mounted, failed with error: N o such file or directory
    now formatting formatting /dev/fs0p3
    checkPersistence: trying to backup the corrupted flash: ('.' == 1M)
    checkPersistence: error reading flash.
    Unable to open file : No such file or directory
    checkPersistence: error formatting with 'flashctl -e -f -m -v -l 29M -n /mnt/efs -persist -p /dev/fs0p3'...
    Подскажите пожалуйста что можно с этим сделать?
  18. #818
    Киев
    [>>> parkHDD <<<]
    cleanup navi done
    parkHDD done
    самый быстрый путь - отдать специалистам. :-)
  19. #819
    гениально
  20. #820
    Киев
    гениально это спрашивать помощь без понимания предмета.
