i have tried to recovery a unit from failed update.
the unit at this moment start up correctly.
but if i try to install the maps (2015) all the update go failed.
during the boot i have see this strange error:
[WRN]@35874 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35918 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35924 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35938 (122905.9): Try to fix connection...
[WRN]@35946 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35955 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35963 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35979 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@35983 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@36030 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@36037 (122905.9): Try to fix connection...
[WRN]@36043 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@36079 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@36116 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[NATIVE-RESMGR-PROXY]: No valid GEMMI installation found - stop
[t(p) proc/boot/procnto-instr 1 1 0 8807a22e]
[WRN]@38005 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@38058 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@38107 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@38146 (122905.9): Try to fix connection...
[WRN]@38206 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@38261 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
[WRN]@38297 (122905.9): devctl '0X4090055C' <DCMD_HB_HDDMGR_GETDRIVEIDENTITY> call failed(errCode = 5 <Input/output error>)
i think are a problem with the Hard disk but i'm unable to recovery this problem :-(
anyone have solved a similar problem?
