адрес благодаря которому можно считать еепром. в Вашем случае надо взять программатор и залить правильный еепром.
Последний раз редактировалось Timur_ua; 02.10.2014 в 18:42.
) ну ты же знаешь ) перепутал ) пью пиво в турции )
One question to the team: Situation after A failed Flash: "BIOS: no packet found!" The EMG-IFS and the FlashIt command works! Is it Possible to Re-Flash the bios? Where to Find the Binary file? Thanks A lot guys, for your Assistance !!!
your device ?
It´s a HS9308, the emg-ifs works, then I think it must be able to reflash the bios by flashit command...
log
9308_flash_scan:
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_FPGA_9308_D1_09324A
(0ms)
Entering CLI, type '?' or 'help' for help
=> scan
** @0x80040000: FPGA
total size: 746472 [0x0b63e8]
data: 746212 [0x0b62e4]
.FDR = PL_MMI3G_FPGA_9308_D1_09324A
.FDU = Userinfos zu FPGA 9308_D1_4010_10fv
** @0x80100000: FPGA
.FDR = PL_MMI3G_FPGA_9308_D1_08492A
** @0x801c0000: IFS [vers.1, UCL, old EMERGENCY]
total size: 4666284 [0x4733ac]
- header: 256
- startup: 53512
- imagefs: 11565604
RAM: 11619116 [0xb14b2c]
** @0x80780000: IFS [vers.1, LZO, old APPLICATION]
total size:36811020 [0x231b10c]
- header: 256
- startup: 53512
- imagefs: 85729020
RAM: 85782532 [0x51cf004]
Последний раз редактировалось Tschako; 03.12.2014 в 03:14.
9308_boot_log:
BIOS: No packet found!
(0ms)
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001e
*** Old-fashioned mark found on IFS @0x780000: .zero=0x10000000
starting image @780000 ...
Ð*]عtup: PL_qnx_startup-sh7785_08362A, built 2008/09/02_07-53-12_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
NVRAM: 28 MB @0x5e400000
RAM : 228 MB @0x50000000
FLASH: 128 MB @0x00000000
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v8804aa20
Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3G Build 9307/08 D1-10291A
s: 0
v: 0
r: 0
m: 0
mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/efs_symlinks.cfg
done
s: 0
v: 0
r: 0
m: 0
mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/ifs-root_symlinks.cfg
done
üstarting server starter...
# multicored [000000000.666]:version 4.1.d, verbosity 1 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL
multicored [000000000.698]:udp: broadcaster created
multicored [000000000.701]:attached to filesystem at /hbsystem/multicore, port 851
multicored [000000000.705]:MACHINE:SH(1), total MEM 507510784, 1: 271582976 SH7785 (SH4A) 792MHz, FPU
multicored [000000000.709]:sloop active
multicored [000000000.710]:lo0 127.0.0.1 255.0.0.0
NVLOADER: Booting DSP (DRAM Setup time = 1000 us)...
NVLOADER: Going to call nvTsrmRawLoad for file /etc/NvDspCodecs.elf
NVLOADER: Done
Enabling DMA using channel 7
Overriding default Interrupt Priority
Current debug level = 0x7fffffff
dmaChannel = 7, interrupt thread priority = 21
multicored [000000001.214]:listener on port 851 active, fd=7
devg-NVMEM: Mapped vaddr 0x38100000 to paddr 0x5c487000
dev-nvram: PL_qnx_dev-nvram_07225A, built 2007/06/01_15-44-08_UTC
dev-nvram: page_size:4096
dev-nvram: signalling register 10ee:9308:0:40:40 [vid:did:barffs:mask]
dev-nvram: CPU: SH7785 (5th cut or higher, clk_mode 20) [10300700:250, 133735fa]
dev-nvram: map '/dev/nvram/navi' to 0x5e400000-0x5fffefff
dev-nvram: map '/dev/nvram/.guard' to 0x5ffff000-0x5fffffff
dev-nvram: SelfRefresh was inactive
UART: Mod:0E Date:08511A Ver:2.2.1
devc-ser8250hb: UART supports FiFo counter
devc-ser8250hb: UART supports 32bit access
devc-ser8250hb: RX_FIFO_SIZE:512 TX_FIFO_SIZE:512
devc-ser8250hb: set IBUF size to 4096
devc-ser8250hb: RX_FIFO_SIZE:32 TX_FIFO_SIZE:32
WARNING: NON PERFORMANT MODULAR STARTUP!!!
Debug filehandle = 4
For further debug messages have a look at multicore output consoles '/hbsystem/multicore/navi/g'
Mask = c3
GPIO 7 set to = Low
TraceClientLogSink#processConfigChanged silent: false
DSIVersion: 0.0.0
DSISource: DSI 2009_49_49
DSI-Build-Version: 30.11.09/v1.138.3
ReleaseLabel: Integration_AU_MMI3G_10070P
io-media-nvidia built: Mar 4 2009 16:48:41 against Official Tree
nv_global.verbose = 0
start JDSI bundle
jdsi.loglevel : 2Virtual Address for CDDA DirectIO = 8394000
No External Component found
stream factory memory mode : classic
dsigen v1.138.3 - core v2.1
prop os.arch : sh4
prop jdsi.3SoftOSGi : true
DSI dispatcher disabled!
NEDL: Acquiring Capture Unit
NEDL: Acquiring Layer
NEDL: Switching source to 0 (Format = PAL)
NvRender: Reconfigure Video Port to PAL
[MSG]@6136 (77861.161): COnOffPresCtrl::requestSetPowerState(), state: 3
[MSG]@6495 (77861.161): COnOffPresCtrl: IOCBoloMode: 0
[MSG]@6496 (77861.161): -- getHardwareSample: state=2 -- hwSample = 0xd1
[MSG]@6496 (77861.161): -- getHardwareVariant: state=2 -- hwVariant = 0x7
[MSG]@6497 (77861.161): COnOffPresCtrl: newSystemState: 20
[MSG]@6559 (77861.161): +++ PRODUCTION_MODE is 0
[MSG]@6563 (77861.161): +++ remounting of the efs partitions is done, persistency is set to fully operable...
[MSG]@6602 (77861.161): COnOffPresCtrl: newSystemState: 35
NEDL: Enabling Capture
msgpassing channel opened on /dev/dsi/data
NAVI: sys_alloc_shm_area(/dev/nvram/navi) open() ok: 39
NAVI: sys_alloc_shm_area(/dev/nvram/navi) filesize() = 29356032
NAVI: sys_alloc_shm_area(/dev/nvram/navi) mmap to 50000000
NAVI: sys_alloc_shm_area(/dev/nvram/navi): physical of 50000000 at 5e400000
[MSG]@6958 (77861.161): +++ persistency StartupMode is 1
[MSG]@6990 (77861.161): +++ TEL_SETTINGS_REST is 3
[MSG]@6991 (77861.161): +++ setting BtAvailable to true
[MSG]@6998 (77861.161): +++ ReadInt FLAG_SYSTEM_RESET, Value 1
[MSG]@7007 (77861.161): +++ MISC_HB_REGIONCODE 0
NEDL: Switching source to 0 (Format = NTSC)
NvRender: Reconfigure Video Port to NTSC
NvRender: Starting VIP Video Capture
DSIAddressbook (0) - v10.0G1.138.3
DSIAddressbook (1) - v10.0G1.138.3
DSIAddressbook (2) - v10.0G1.138.3
DSIAddressbook (3) - v10.0G1.138.3
DSIAMFMTuner (0) - v8.0G1.138.3
DSIAudioManagement (0) - v8.1G1.138.3
DSIBluetooth (0) - v4.3G1.138.3
DSIBrowser (0) - v4.0G1.138.3
DSIBrowser (1) - v4.0G1.138.3
DSIBrowser (2) - v4.0G1.138.3
DSICallLists (0) - v3.0G1.138.3
DSICarClimate (0) - v4.0G1.138.3
DSICarComfort (0) - v3.0G1.138.3
DSICarParkingSystem (0) - v2.4G1.138.3
DSICarSuspensionControl (0) - v1.0G1.138.3
DSICarLight (0) - v2.0G1.138.3
DSICarService (0) - v3.2G1.138.3
DSICarDriverAssistance (0) - v2.0G1.138.3
DSICarKombi (0) - v4.4G1.138.3
DSIDABTuner (0) - v5.3G1.138.3
DSIDiagHMIAttribs (0) - v4.0G1.138.3
DSIIconrenderer (0) - v1.0G1.138.3
DSIIconrenderer (1) - v1.0G1.138.3
DSIDataDisplay (0) - v5.0G1.138.3
DSIDisplayManagement (0) - v9.6G1.138.3
DSIInfotainmentRecorder (0) - v2.0G1.138.3
DSIKeyPanel (0) - v2.3G1.138.3
DSIMapViewer (0) - v18.3G1.138.3
DSIMedia (0) - v4.6G1.138.3
DSIMediaRecorder (0) - v1.4G1.138.3
DSIMOSTInfo (0) - v3.0G1.138.3
DSINavigation (0) - v72.0G1.138.3
DSIObexAuthentication (0) - v1.0G1.138.3
DSIPhonoConv (0) - v1.0G1.138.3
DSIPersistence (0) - v10.1G1.138.3
DSIPowerManagement (0) - v3.4G1.138.3
DSIStartup (0) - v1.2G1.138.3
DSIProfileManager (0) - v6.0G1.138.3
DSISDARSTuner (0) - v2.2G1.138.3
DSISMS (0) - v4.1G1.138.3
DSISound (0) - v8.0G1.138.3
DSISSS (0) - v6.2G1.138.3
DSISwdlDeviceInfo (0) - v1.1G1.138.3
DSISwdlLogging (0) - v1.1G1.138.3
DSISwdlProgress (0) - v1.2G1.138.3
DSISwdlSelection (0) - v2.7G1.138.3
DSITelephone (0) - v10.0G1.138.3
DSITIMTuner (0) - v2.3G1.138.3
DSITmc (0) - v9.2G1.138.3
DSITmcOnRoute (0) - v6.0G1.138.3
DSITTS (0) - v4.0G1.138.3
DSITTS (1) - v4.0G1.138.3
DSITunerAnnouncement (0) - v1.0G1.138.3
DSITVTuner (0) - v5.2G1.138.3
DSIVCardExchange (0) - v5.0G1.138.3
DSIWavePlayer (0) - v5.2G1.138.3
DSIWavePlayer (1) - v5.2G1.138.3
Duration of starting JDSIBundle : 3124ms
decoder thread priority : 2000:0 (5)
decoder thread priority : 100:0 (5)
CHBComponentMux.cpp:317: ASSERTION failed
CHBComponentMux.cpp:275: ASSERTION failed
decoder thread priority : 12:0 (5)
[MSG]@7693 (77861.161): +++ HW index: d1 variant: 9307
[MSG]@7709 (77861.161): +++ MISC_HB_REGIONCODE 0
High Nav: 91
decoder thread priority : 9:0 (5)
AS: 2CPS: 3
decoder thread priority : 4:0 (5)
AS: 2
AS: 3
decoder thread priority : 50:0 (5)
AS: 3
decoder thread priority : 24:0 (5)
decoder thread priority : 51:0 (5)
decoder thread priority : 8:0 (9)
AS: 1
AS: 2
decoder thread priority : 7:0 (5)
AS: 3
decoder thread priority : 3:0 (5)
decoder thread priority : 32:0 (5)
The message must not be null or of zero length
decoder thread priority : 20:0 (5)
[pcidma] finished.
Audi-2D library version: 20080626
Using NVIDIA driver
[MSG]@66385 (77861.161): COnOffPresCtrl::requestSetPowerState(), state: 3
Товарищи, путём долгих ухищрений удалось сделать usb ttl как доктор прописал. 1 2 3 Делалось не так для продажи, как для активизации интереса к этой теме. UkNik нарисовал, я же собственноручно резал платы, паял и тестил. Отлично втыкается сбоку mmi при выломаной железочке. Самое сложное было найти разъём HSEC, заказать и оплатить. Если Сергей Ник посчитает, что я злостный барыга, то я уберу, конечно, это сообщение. Ну и если интересно, пишите в личку. Если у UkNik-а дойдут руки до JTAG, то ещё и закажем платы и распаяем его в будущем, благо разъёмов пришлось заказать 100 штук (sic lol).
Последний раз редактировалось zerbino; 09.12.2014 в 22:54.
Прикольно получилось, интересует цена данного устройства.
well done.
I'm interested in the price too.
Мужчины) так и хочется в рифму ответить Ладно заслуженный картораздаватель Сергей Ник, но вы то видели, что в ЛС просил писать?) Тему то не закакивайте.
дабы не было вопросов и недоумений, я вам хочу сообщить, что только один разъём 20ти контактный стоит 500р.
Последний раз редактировалось zerbino; 10.12.2014 в 19:51.
еепром европейский. пробовал обратно китайский заливать и прошивать - дудки...
вот лог гляньте пож https://cloud.mail.ru/public/b90d7b0cf38f/850.log
