спрячьте лог под спойлер пожалуйста.
Не восстановил IFS
Прошу совета, что далее? лог внизу
[spoiler]
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.07.26 09:33:58 =~=~=~=~=~=~=~=~=~=~=~=
getdip
close
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_11384A (0ms)
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x3000001a
!!! Could not find an application IFS.
Try ermergency FPGA and IFS instead!
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_09422A
(0ms)
*** emergency FPGA loaded!
starting image @1c0000 ...
Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
RAM : 256 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v88046ae0
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_09423A) MMI3G Audi EMERGENCY SETUP 15325A
starting pci driver
*** init FPGA registers ***
[pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
starting dev-ipc for IOC
initialize IPC Driver
starting network driver
starting atapi driver - setup device /dev/cam0
dev-ipc:queueGetWritePtrExt:queueGetFreeElements = 0
Statistics Watchdog
Count : rx 1 / tx 1
Msg cnt: rx 0 / tx 0
Statistics Watchdog
Count : rx 1 / tx 1
Statistics Watchdog
Count : rx 2 / tx 1
starting devc-pty
starting flash driver
Path=0 -dev-ipc:queueGetWritePtrExt:queueGetFreeElements = 0
Statistics Watchdog
Count : rx 2 / tx 1
XILINX ATAPI
target=0 lun=0 CD-ROM(5) - FJ-TEN DVD-ROM DV-05FT2 Rev: 1B20
Path=1 - XILINX ATAPI
target=1 lun=0 Direct-Access(0) - TOSHIBA MK6050GA Rev: TJ10
Statistics Watchdog
Count : rx 3 / tx 1
Statistics Watchdog
Count : rx 3 / tx 1
starting SDCard driver
Statistics Watchdog
Count : rx 4 / tx 1
Statistics Watchdog
Count : rx 4 / tx 1
Statistics Watchdog
Count : rx 5 / tx 1
Statistics Watchdog
Count : rx 5 / tx 1
Statistics Watchdog
Count : rx 6 / tx 1
Statistics Watchdog
Count : rx 6 / tx 1
Statistics Watchdog
Count : rx 7 / tx 1
Statistics Watchdog
Count : rx 7 / tx 1
Statistics Watchdog
Count : rx 8 / tx 1
Statistics Watchdog
Count : rx 8 / tx 1
Unable to access "/dev/io-net/en5" (2)
starting with no network driver
Emergency IFS is started. Emergency app tries to restore
the application.
49169 running /usr/bin/devg-NVTIRM
DMA is Disabled
dma disabled, interrupt thread priority = 100
Statistics Watchdog
Count : rx 9 / tx 1
49171 running /sbin/io-media-nvidia
49172 running /usr/sbin/io-display
49173 running /usr/apps/MMI3GEmergencyApp
Emergency shell started, fix your system and restart again
discplayer_init: IN
nvidia_render_manager_init: IN
INvmRenderManager::GetNvmRenderManager (&pRenderManager);
er = pRenderManager->Init(oConfig);
# App FPGA valid 1
Emergency FPGA valid 1
Disabling IOC watchdog
EmergencyApp-MMI3G: version 37.26.2098, date of build 07.08.2015
pRenderManager->Open()
nvidia_render_manager_init: OUT
discplayer_init: OUT
discplayer_init
discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
created navigator control point with 8249288
mixer_init: IN
mixer_init: OUT
NvTRACELEVEL set to 3 (Level Info)
nVAudio_init: IN
nvidia_render_manager_init();
nVAudio_init: OUT
installing audio decoders
installing video decoders
nVAudio_init: IN
nVAudio_init: OUT
OnIpcGetCaptureUnitSourceCount
Number of displays: 6
Number of layers: 9
Graphics init was successfull: DisplaySize is 800x 480
The FPGA for the application is valid!
Emergency application will do nothing!
result of running command start_efs_driver.sh is 0
HBpersistence is available!
******** DeveloperMode is on ******************************
Set DisplayStatus to 2
Set DisplayStatus to 4
OnOff: process IPC event HWsample 209 HWvariant 198 FinalShutdown 0
Set DisplayStatus to 6
[/spoiler]
нужна помощь
Я попытался исправить свой HARMAN Mib1 (GOLF 7), но что-то пошло не так. Моей целью было получить (CP REMOVE)
Загрузочная прошивка была MHIG_EU_VW_S1054_MU0290
Шаги, которые я выполнил:
1) Обновление прошивки красного меню с MHIG_EU_VW_S1054_MU0290 до MHIG_EU_VW_K1550_MU0407. Этот шаг прошел хорошо.
2) Сохранение системных файлов на SD-память через Putty (eeprom, FecContainer.fec, mmx_fs0, mmx_fs0, Variant)
3) Фикс прошивки с помощью MHIG_EU_VW_K1550 MU0407_patch_CP, скачанный с Mega. nz, вкупе с той же прошивкой, начиная с 0x00BA0000.file ~~ 20MB (может это ошибка?) СМОТРЕТЬ ИЗОБРАЖЕНИЕ НИЖЕ
4) перезапуск
Текущая ситуация :
- Устройство запускается, но зависает на LOGO
- Из Putty через USB-Ethernet я могу получить доступ только к порту 23 (mmx), а НЕ к порту 123 (rcc). Служба не отвечает на порт 123
- Блок управления 5F больше не реагирует на сканирование VCDS.
Мог ли я перепутать адреса патчей?
Как вы думаете, ситуацию можно исправить?
- По возможности прошил бы все RCC с бэкапом rcc_fs0, но доступ из mmx потому что не работает rcc, либо доступ через UART WITH TX RX
Что вы думаете ?
извините за перевод
большое спасибо
Вложение 70668Вложение 70669
try to update unit via emergency mode
i access via UART Rx Tx and enter to IPL mode
i putted boot -t emerg then i got those lines
ERROR: /net/mmx/ramdisk/eassist doesn't exist
Failed to output BGcolor normal
Failed to output Version 30.937
Failed to output Info1Text TransactionImage is valid !Вложение 70670
insert SD card with firmware and try again
i tried with sd card firmware same thing !
i have some thing in the begining "IOC boot mode error " is that normal ?
Вложение 70671
Доброго времени, уважаемые господа! Прошу помочь...
Имеется MMI 3G с Audi Q5 2010 Америка. Не включается дисплей, клавиатура не подсвечивается. Есть подозрение что дисплей тоже не работает (стоит не родной, с каким-то блоком-преобразователем на котором нет питания или пока нет питания).
MMI снял, машина уехала. Подключил на столе через UART, MOST не закольцовывал.
При включении начинает загрузку с 0х00780000.
Имею вопросы:
1. "! [JDSI_Channel] Cannot open Transport: QMPTransport: could not attach to /dev/dsi/data
! [JDSI_Channel] Warning: Channel not started!"
Это относится к оптике? Что значит "QMPTransport"?
"! [JDSI_Activator] send stream failed - channel not running!" - так понимаю, это следствие вышеуказаного.
2. "Unrecoverable HMI Error, trigger a system shutdown!" - Это последствия п.1?
3. "Unrecoverable HMI Error, trigger a system reset!" - Это последствия п.п. 2 и 1?
Вот лог:
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_07412A, built 2007/10/09_12-19-44_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20), 792MHz
FLASH: Spansion S29GL512N: 512 sectors x 256K
FPGA: PL_MMI3G_FPGA_9308_D1_08164A (0ms)
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x30000019
*** Old-fashioned mark found on IFS @0x780000: .zero=0x10000000
starting image @780000 ...
Startup: , built 2011/07/19_09-41-26_UTC
Starting next program at v8804aae0
Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3G Build 9307/08 D1-11303A
USB-stuff (QNXLabel RL_qnx_os_632_PSP3_08041A)
s: 0
v: 0
r: 0
m: 0
mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/efs_symlinks.cfg
done
s: 0
v: 0
r: 0
m: 0
mkprocsymlinks 0.10, reading /mnt/ifs-root/etc/system/ifs-root_symlinks.cfg
done
starting server starter...
# multicored [000000001.866]:version 4.2.d, verbosity 1 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
NVLOADER: Booting DSP (DRAM Setup time = 1000 us)...
multicored [000000001.892]:udp: broadcaster created
NVLOADER: Did not find any TI DM642 DSP device
multicored [000000001.895]:attached to filesystem at /hbsystem/multicore, port 851
multicored [000000001.900]:MACHINE:SH(1), total MEM 536870912, 1: 271582976 SH7785 (SH4A) 792MHz, FPU
multicored [000000001.900]:sloop active
multicored [000000001.902]:lo0 127.0.0.1 255.0.0.0
Enabling DMA using channel 7
Overriding default Interrupt Priority
Current debug level = 0x7fffffff
dmaChannel = 7, interrupt thread priority = 21
multicored [000000001.987]:listener_activate()
multicored [000000001.989]:listener on port 851 active, fd=7
devg-NVMEM: Mapped vaddr 0x38100000 to paddr 0x5f63f000
dev-nvram: PL_qnx_dev-nvram_07225A, built 2007/06/01_15-43-18_UTC
dev-nvram: page_size:4096
dev-nvram: signalling register 10ee:9308:0:40:40 [vid:did:bar:offs:mask]
dev-nvram: CPU: SH7785 (5th cut or higher, clk_mode 20) [10300700:250, 133735fa]
dev-nvram: 'nvram' entry could not be found in syspage
dev-nvram: Mapping NVRAM failed 'navi', size:28668k
dev-nvram: exit(1)
UART: Mod:0E Date:07411A Ver:2.0.3
devc-ser8250hb: UART supports FiFo counter
devc-ser8250hb: UART supports 32bit access
devc-ser8250hb: RX_FIFO_SIZE:512 TX_FIFO_SIZE:512
devc-ser8250hb: set IBUF size to 4096
devc-ser8250hb: RX_FIFO_SIZE:32 TX_FIFO_SIZE:32
/lsd/lsd.sh[7]: : not found
Debug filehandle = 4
For further debug messages have a look at multicore output consoles '/hbsystem/multicore/navi/g'
multicored [000000002.508]:lo0 127.0.0.1 255.0.0.0
Mask = c3
GPIO 7 set to = Low
multicored [000000003.017]:lo0 127.0.0.1 255.0.0.0
JVMEXEL085W
WARNING: The command line argument "-jxe:" has been deprecated.
WARNING: Use "-jxe <path>" instead.
multicored [000000003.612]:lo0 127.0.0.1 255.0.0.0
DSIVersion: 0.0.0
DSISource: DSI 2008-11_12
DSI-Build-Version: 12.03.08/v1.137.5
ReleaseLabel: Integration_SOP1_819Q_KRP
start JDSI bundle
External Component Instance created
dsigen v1.137.5 - core v2.0
prop os.arch : sh4
prop jdsi.3SoftOSGi : true
DSI dispatcher disabled!
multicored [000000004.468]:lo0 127.0.0.1 255.0.0.0
cd0 mounted after 1 try
Path=0 - XILINX MMI3G_8
target=0 lun=0 CD-ROM(5) - FJ-TEN DVD-ROM DV-04FT1 Rev: 1423
Path=1 - XILINX MMI3G_8
target=1 lun=0 Direct-Access(0) - TOSHIBA MK4050GA Rev: TG10
multicored [000000005.225]:lo0 127.0.0.1 255.0.0.0
multicored [000000005.867]:lo0 127.0.0.1 255.0.0.0
multicored [000000006.606]:lo0 127.0.0.1 255.0.0.0
multicored [000000007.121]:lo0 127.0.0.1 255.0.0.0
multicored [000000007.636]:lo0 127.0.0.1 255.0.0.0
multicored [000000008.151]:lo0 127.0.0.1 255.0.0.0
multicored [000000008.666]:lo0 127.0.0.1 255.0.0.0
multicored [000000009.182]:lo0 127.0.0.1 255.0.0.0
msgpassing channel opened on /dev/dsi/data
DSIModelAPI (0) - v5.1G1.137.5
DSINavServicesAPI (0) - v5.1G1.137.5
DSIAddressbook (0) - v9.2G1.137.5
DSIAddressbook (1) - v9.2G1.137.5
DSIAddressbook (2) - v9.2G1.137.5
DSIAddressbook (3) - v9.2G1.137.5
DSIAMFMTuner (0) - v7.0G1.137.5
DSIAudioManagement (0) - v8.1G1.137.5
DSIBluetooth (0) - v4.3G1.137.5
DSIBrowser (0) - v4.0G1.137.5
DSIBrowser (1) - v4.0G1.137.5
DSIBrowser (2) - v4.0G1.137.5
DSICallLists (0) - v3.0G1.137.5
DSICarClimate (0) - v4.0G1.137.5
DSICarComfort (0) - v3.0G1.137.5
DSICarParkingSystem (0) - v1.3G1.137.5
DSICarSuspensionControl (0) - v1.0G1.137.5
DSICarLight (0) - v2.0G1.137.5
DSICarService (0) - v3.2G1.137.5
DSICarDriverAssistance (0) - v2.0G1.137.5
DSICarKombi (0) - v4.4G1.137.5
DSIDABTuner (0) - v5.2G1.137.5
DSIDiagHMIAttribs (0) - v2.1G1.137.5
DSIIconrenderer (0) - v1.0G1.137.5
DSIIconrenderer (1) - v1.0G1.137.5
DSIDataDisplay (0) - v5.0G1.137.5
DSIDisplayManagement (0) - v9.5G1.137.5
DSIInfotainmentRecorder (0) - v2.0G1.137.5
DSIKeyPanel (0) - v2.3G1.137.5
DSIMapViewer (0) - v18.1G1.137.5
DSIMedia (0) - v4.5G1.137.5
DSIMediaRecorder (0) - v1.4G1.137.5
DSIMOSTInfo (0) - v3.0G1.137.5
DSINavigation (0) - v70.0G1.137.5
DSIObexAuthentication (0) - v1.0G1.137.5
DSIPhonoConv (0) - v1.0G1.137.5
DSIPersistence (0) - v10.0G1.137.5
DSIPowerManagement (0) - v3.4G1.137.5
DSIStartup (0) - v1.2G1.137.5
DSIProfileManager (0) - v6.0G1.137.5
DSISDARSTuner (0) - v2.2G1.137.5
DSISMS (0) - v4.1G1.137.5
DSISound (0) - v8.0G1.137.5
DSISSS (0) - v6.2G1.137.5
DSISwdlDeviceInfo (0) - v1.1G1.137.5
DSISwdlLogging (0) - v1.1G1.137.5
DSISwdlProgress (0) - v1.2G1.137.5
DSISwdlSelection (0) - v2.6G1.137.5
DSITelephone (0) - v9.0G1.137.5
DSITIMTuner (0) - v2.2G1.137.5
DSITmc (0) - v9.0G1.137.5
DSITmcOnRoute (0) - v6.0G1.137.5
DSITTS (0) - v4.0G1.137.5
DSITTS (1) - v4.0G1.137.5
DSITunerAnnouncement (0) - v1.0G1.137.5
DSITVTuner (0) - v4.5G1.137.5
DSIVCardExchange (0) - v5.0G1.137.5
DSIWavePlayer (0) - v5.1G1.137.5
DSIWavePlayer (1) - v5.1G1.137.5
Duration of starting JDSIBundle : 5670ms
multicored [000000009.697]:lo0 127.0.0.1 255.0.0.0
multicored [000000010.213]:lo0 127.0.0.1 255.0.0.0
multicored [000000010.728]:lo0 127.0.0.1 255.0.0.0
multicored [000000011.243]:lo0 127.0.0.1 255.0.0.0
multicored [000000011.759]:lo0 127.0.0.1 255.0.0.0
multicored [000000012.275]:lo0 127.0.0.1 255.0.0.0
multicored [000000012.790]:lo0 127.0.0.1 255.0.0.0
multicored [000000013.305]:lo0 127.0.0.1 255.0.0.0
multicored [000000013.823]:lo0 127.0.0.1 255.0.0.0
multicored [000000014.337]:lo0 127.0.0.1 255.0.0.0
multicored [000000014.852]:lo0 127.0.0.1 255.0.0.0
multicored [000000015.367]:lo0 127.0.0.1 255.0.0.0
multicored [000000015.882]:lo0 127.0.0.1 255.0.0.0
multicored [000000016.398]:lo0 127.0.0.1 255.0.0.0
multicored [000000016.914]:lo0 127.0.0.1 255.0.0.0
multicored [000000017.429]:lo0 127.0.0.1 255.0.0.0
multicored [000000017.945]:lo0 127.0.0.1 255.0.0.0
multicored [000000018.461]:lo0 127.0.0.1 255.0.0.0
multicored [000000018.976]:lo0 127.0.0.1 255.0.0.0
multicored [000000019.492]:lo0 127.0.0.1 255.0.0.0
multicored [000000020.007]:lo0 127.0.0.1 255.0.0.0
multicored [000000020.523]:lo0 127.0.0.1 255.0.0.0
multicored [000000021.039]:lo0 127.0.0.1 255.0.0.0
multicored [000000041.654]:lo0 127.0.0.1 255.0.0.0
multicored [000000042.169]:lo0 127.0.0.1 255.0.0.0
multicored [000000042.182]:startup phase ending for 0
multicored [000000042.685]:lo0 127.0.0.1 255.0.0.0
multicored [000000043.201]:lo0 127.0.0.1 255.0.0.0
multicored [000000183.408]:lo0 127.0.0.1 255.0.0.0
multicored [000000183.923]:lo0 127.0.0.1 255.0.0.0
multicored [000000184.461]:lo0 127.0.0.1 255.0.0.0
multicored [000000184.977]:lo0 127.0.0.1 255.0.0.0
multicored [000000405.595]:lo0 127.0.0.1 255.0.0.0
multicored [000000406.110]:lo0 127.0.0.1 255.0.0.0
ג@
На этом она выключается.
Оптику закольцевать. LOG посмотреть. И память глянуть.
Спасибо, жду кольцо оптики чтобы по правильному закольцевать.
"И память глянуть." - что Вы имели в виду - посмотреть есть ли свободное место, проверить физически на плате или же каким-либо образом просканировать на целостность секторов?
И Вам спасибо за подказку. Emergency не запускал.
Да, я пока в этом не специалист, но есть желание освоить, потому сейчас изучаю информацию по QNX и логам MMI. Пытаюсь понять происходящее во время загрузки и выявить причину её остановки. Ничего не спешу удалять либо запускать не поняв зачем.
В субботу получу кольцо оптики и с ним снова посмотрю лог. Если [JDSI_Channel] заработает, значит это все же канал оптики и Clark помог з ответом на первый вопрос.
Теперь, догадываюсь, если Emergence Update пройдет нормально, то заголовки на своих местах и данные для загрузки целые, а значит с памятю все хорошо и Вы помогли понять что подразумевал Clark в фразе "И память глянуть."
PS: я понимаю, что не каждому интересно учить кого-то, ражовывая "елементарные" вещи, но ответ знающего человека иногда позволяет здвинутся с места непонимания того что имеет в виду "книжка".
мми 3G, кто мог потсказат sh4 бес ram лог показывает или нет?
сдох sh4, тоест дата линии 3 на флаш. поставил от cic, проц по jtag визу но не могу обознат флаш и нету лога пока. думп ок. флаш снимал.
Закольцевал оптику - ничего не изменилось, лог прежний.
Попытался запустить ifs em - получил:
Unable to access "/dev/pci"
Unable to access "/dev/sysregs" (2)
main: Unable to locate pci server
IFS Emergency остановилась на
"The FPGA for the application is valid!"
Есть-ли возможность загрузится через Emergency с SD-картки?
"echo dummy > / HBPersistence / Developermode" работает
определения каталога и содержимого:
#pwd
# ls
HBdata dev proc usr
HBpersistence etc sbin
bin lib tmp
Лог:
Entering CLI, type '?' or 'help' for help
=> help
? - alias for 'help'
bconf - display boot manager configuration
bios - start BIOS
boot - boot image in memory/flash
diag_p1j - diagnostic for the PLL1 clock jitter problem
download - download IFS over serial line (sendnto protocol)
echo - echo args
fpga - load FPGA from image in memory/flash
go - jump to 'addr'
help - print online help
hwconf - dump hardware configuration
md - memory display
memperf - memory performance test (benchmark)
memtest - memory test
mt - alias for 'memtest'
pci - lists pci devices
qinfo - display QNX build information
rsupdate - query read shifter update mode (workaround for SH7785 limitation #48)
rz - alias for 'zmodem'
scan - scan flash for images (FPGA, IFS, BIOS packet)
version - print program version
zmodem - download IFS or FPGA over serial line (Z-Modem protocol)
=> scan
** @0x80040000: FPGA
total size: 746492 [0x0b63fc]
data: 746212 [0x0b62e4]
.FDR = PL_MMI3G_FPGA_9308_D1_08164A
.FDU = Userinfos zu FPGA 9308_D1_4010_10fv
** @0x80100000: FPGA
.FDR = PL_MMI3G_FPGA_9308_D1_08142A
** @0x801c0000: IFS [vers.1, LZO, old EMERGENCY]
total size: 4835812 [0x49c9e4]
- header: 256
- startup: 53512
- imagefs: 11230256
RAM: 11283768 [0xac2d38]
** @0x80780000: IFS [vers.1, LZO, old APPLICATION]
total size:30421584 [0x1d03250]
- header: 256
- startup: 53512
- imagefs: 67505916
RAM: 67559428 [0x406e004]
** @0x87f00000: BIOS packet
total size: 16384 [0x004000]
BIOS pattern: FFFFFFFF.FFFFFFFF
App. pattern: FFFFFFFF.FFFFFFFF
=> boot 1c0000
starting image @801c0000 ...
Startup: PL_qnx_startup-sh7785_Rel07252A_08105A, built 2008/03/07_17-24-06_UTC
RAM: 128 MB @0x08000000
RAM: 128 MB @0x40000000
RAM: 256 MB @0x50000000
Starting next program at v880467e0
Welcome to QNX 6.3.2 (RL_qnx_os_632_PSP3_08124A) MMI3G Audi EMERGENCY SETUP 08134A
starting pci driver
Unable to access "/dev/pci" (2)
maxipnt:_ c oUnnfaibgluer et:o lNooc aeidet ei nptceir fsaecrevse rf
oundm
Unable to access "/dev/cam0" (2)
starting devc-pty
the application.
53260 running /usr/bin/dev-ipc
53261 running /usr/bin/ipc-test
53262 running /usr/bin/devg-NVTIRM
53261 exited with status 0
DMA is Disabled
Unable to locate DM642
Process 53262 (devg-NVTIRM) terminated SIGSEGV code=1 fltno=11 ip=080418a2 ref=0001fff4
53262 terminated with signal 11
61454 running /sbin/io-media-nvidia
61455 running /usr/sbin/io-display
61456 running /usr/apps/MMI3GEmergencyApp
discplayer_init: IN
# App FPGA valid 1
EmergencyApp-MMI3G: version 19.25.1362, date of build 20.pRenderManager->Open()
0nvidia_render_manager_init: OUT
3discplayer_init: OUT
.discplayer_init
2008discplayer_init: IN
dvdtrackplayer_init
discplayer_init: IN
dvdnavigator_init
mixer_init: IN
mixer_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
nVAudio_init: IN
nVAudio_init: OUT
Number of layers: 9
