He meaning that he has patched unit from APG :) Without blocking sound even if CP is on.
Unfortunately I don't know. I was used their units. Units was with CP error, but sound was not muted, also unit had Golf VIN on all of them, I think APG - is software solution with custom GEM (with disable/enable diagnostic option)
I have a question. I completely flashed all known partiotions in MIB from Emerg mode, but how I can flash app.img on MIB? Does some specific address, you know? btw. I took Adresses from metainfo2.txt from original firmware but there are no address for app.img
Thanks..
Some body have that firmware:
MHI2_ER_SKG11_P0260
MHI2_ER_SKG11_P2104
MHI2_ER_SKG11_P2129
for mib 2 Columbus?
Why do U need those old version?
Sent me your eeprom.
I second the above request, I need some of these softwares:
MHI2_ER_SKG11_P0260
MHI2_ER_SKG11_P2104
MHI2_ER_SKG11_P2129
I have a very old MIB2 Skoda Columbus with sw 0200 and I can't update because train is blocked. I can't modify the eeprom because I don't have the root pass for sw 0200.
Anybody can share the above softwares or a root pass for 0200?
Password for energency not harman_f?
For emergency the pass is still harman_f, but I need the MMX pass as in RCC I cannot use modifyE2P because of missing DSI.
Thanks for your help, I am learning a lot with you, I try to undestand the structure and do not brick more my MMX.
I dumped mnand0 to sda0 with cat ... > file.img and most content from 0x0 to 0x7FFF is F3DEBC9A (attached img): Is it the expected header to paste into app.img?
Вложение 69504
