who can activate me or tell me how to activate appconnect on unit MST2_EU_SE_ZR_P0515T
thank you, but it's not the same procedure for MST2_EU_SE_ZR_P0515T
Solution is same for all Technisat/Preh devices. Maybe your 5F has different variant than listed in metainfo2 file - if yes U need to patch device via eMMC ISP method.
I patched it using the emmc method, but the unit restarts several times after the patch, then after the 4th time it starts normally but all the fec code disappears and nothing is activated.
no, many will tell you that it is not the same patch method on P05..T
Hi! I can not understand with what program is mentioned in the solution (tutorial.doc) that cnverted from .img to .vmdk
Какой программой конвертировать файл .img в .vmdk (ну и потом обратно)?
Please help.
