This is Label :
Вложение 62803
This is Label :
Вложение 62803
same problem - error 150
- executed various attempts on a manual, but after start of MMI3G EmApp - MMI flashing from the SD card, there passes stage 6\8, is overloaded also in the nomalny mode to install files and have an error 150
- tried to erase areas through IPL, the same result - except 942 firmwares on SD cards does not pick up anything - no any other version of software
- in the terminal having connected on a manual to MMI - there is attempt to the hard drive repeating indefinitely (as I understood, but can I am mistaken) - maybe tries to write CombiStyles ECE - I will not understand (((
- changed HDD (having registered an image from 8 sections from Q7 - take from forum - tested people who replace all everything is OK) in hope that the file system can it is destroyed or the drive died - error 150 too
Meanwhile MMI is included into IPL - but I do not know a kaka still actions to take, commands, can format zones in which information from 942 lies and to roll other firmware...\
