Hello,
i have a patched MIB2 Harman unit in my S3. But Google Maps is not working. After I select Google earth I get error cannot connect to Audi Server. How I can fix it? Maybe I have to change Server address?
Hello,
Do you patch unit? Are you making mibs?
Unit is patched and working. But no google earth or online services. What is mibs?
ok but do you patched it?? You knows how to do it?
Yes patched unit with new ifs-root and added fec codes. Everything work but no google earth
You need make coding to run it.
Which coding?
No work with coding
What i have to do?
If your software is 4XXX or 5XXX then forget about the coding option.
That might work in some cases only on 3XXX firmware.
And how to get working on newer firmwares?
What about coding for 3XXX, does this enable online even if Audi connect license is expired? Or need online license also?
I guess by coding you mean remote_hmi trick?
