MMI 3G A8 Прошу помощи
Здравствуйте. Прошу посмотрите что не так . На диагностику не выходит, дисплей не выдвигается . Не пинайте сильно , занимаюсь bmw в ауди не обычно для меня , друг просил помощь .
Вот загрузка голой головы на столе:
IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
RAM: 512 MB (probed, DBCONF=e30002)
FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_11384A (0ms)
*** Old-fashioned mark found on IFS @0x1c0000: .zero=0x30000013
*** Old-fashioned mark found on IFS @0x680000: .zero=0x10000000
starting image @680000 ...
Startup: PL_qnx_startup-sh7785_11292A, built 2011/07/19_08-03-38_UTC
RAM : 128 MB @0x08000000
RAM : 128 MB @0x40000000
NVRAM: 36 MB @0x5dc00000
RAM : 220 MB @0x50000000
FLASH: 128 MB @0x00000000
FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
System page at phys:0800a000 user:0800a000 kern:8800a000
Starting next program at v8804aae0
Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3GP Buil d 9411 D1 E1-12321A
USB-stuff (QNXLabel RL_qnx_os_632_PSP3_08041A)
# NV: Waiting for the minirm init done indication file /dev/shmem/nvminirm.finis hed'
NVLOADER: Booting DSP (DRAM Setup time = 1000 us)...
NVLOADER: Going to call nvTsrmRawLoad for file /etc/NvDspCodecs.elf
NVLOADER: Done
Enabling DMA using channel 11
Overriding default Interrupt Priority
Current debug level = 0x7fffffff
dmaChannel = 11, interrupt thread priority = 21
devg-NVMEM: Mapped vaddr 0x38100000 to paddr 0x5d527000
[pcidma] PL_qnx_pcidma_FMod08363A_09274A, built 2009/07/02_11-10-37_UTC
multicored [000000001.678]:version 4.6.d, verbosity 1 (supported 4), scope 0x000 00001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
multicored [000000001.680]:using 750 buffers of size 1460 (total 1095000 bytes)
multicored [000000001.721]:version 4.6.d, verbosity 2 (supported 4), scope 0x000 00001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
multicored [000000001.746]:udp: broadcaster created
multicored [000000001.781]:attached to filesystem at /hbsystem/multicore, port 8 51
multicored [000000001.817]:MACHINE:SH(1), total MEM 499122176, 1: 271582976 SH77 85 (SH4A) 792MHz, FPU
multicored [000000001.829]:sloop active
multicored [000000001.831]:lo0 127.0.0.1 255.0.0.0
multicored [000000001.831]:pflog0 0.0.0.0 0.0.0.0
multicored [000000001.858]:listener_activate()
multicored [000000001.860]:listener on port 851 active, fd=7
Unable to post device
common/include/NvRefCountImpl.h:134: NV_ASSERT failed: __INvRefCountIMPL_m_ulRef Count == 0
checkFreeMem: problem getting system time.Audi 3G+ dumper: dumping to /HBpersist ence/core/GPIOSet.core.gz
checkFreeMem: no log to rotate.
/HBpersistence/core/GPIOSet.core.gz: Read-only file system
Could not write to default logfile location
checkFreeMem: problem getting system time.Time of Dump: ---@--,---@6---
checkFreeMem dumping 2048 bytes of serial log
core dumped for pid 36892
sh: no closing quote
Open connection to '/dev/irc'...
Inside Open to
ircCtrl: IRC was flushed successfully
closed.
Process 36892 (GPIOSet) terminated SIGSEGV code=1 fltno=11 ip=08043a5e ref=00000 000
dev-nvram: PL_qnx_dev-nvram_07225A, built 2007/06/01_15-44-08_UTC
dev-nvram: page_size:4096
dev-nvram: signalling register 10ee:9411:0:40:40 [vid:did:bar:offs:mask]
dev-nvram: CPU: SH7785 (5th cut or higher, clk_mode 20) [10300700:250, 133735fa]
dev-nvram: map '/dev/nvram/navi' to 0x5dc00000-0x5fffefff
dev-nvram: map '/dev/nvram/.guard' to 0x5ffff000-0x5fffffff
dev-nvram: SelfRefresh was inactive
UART: Mod:0E Date:09503A Ver:2.2.2
devc-ser8250hb: UART supports FiFo counter
devc-ser8250hb: UART supports 32bit access
devc-ser8250hb: RX_FIFO_SIZE:2048 TX_FIFO_SIZE:2048
devc-ser8250hb: set IBUF size to 16384
devc-ser8250hb: RX_FIFO_SIZE:512 TX_FIFO_SIZE:512
devc-ser8250hb: RX_FIFO_SIZE:32 TX_FIFO_SIZE:32
Debug filehandle = 5
For further debug messages have a look at multicore output consoles '/hbsystem/m ulticore/navi/g'
[pcidma] PL_qnx_pcidma_FMod08363A_09441A, built 2009/10/26_07-46-16_UTC
mam0 available
NAVI: sys_alloc_shm_area(/dev/nvram/navi) open() ok: 9
NAVI: sys_alloc_shm_area(/dev/nvram/navi) filesize() = 37744640
NAVI: sys_alloc_shm_area(/dev/nvram/navi) mmap to 38100000
NAVI: sys_alloc_shm_area(/dev/nvram/navi): physical of 38100000 at 5dc00000
WARNING: NON PERFORMANT MODULAR STARTUP!!!
[t(p) j9/bin/j9 135197 1 9 7853035e]
DSIVersion: 0.0.0
DSISource: DSI 2012_26_26
DSI-Build-Version: Mon Jun 25 11:24:44 CEST 2012 / DSIGEN v1.138.4
ReleaseLabel: Int_AU_EU_Front_SOP9_12272P
start JDSI bundle
HBTRACE: jdsi.verboselevel = null => verbose-level = 0 because property not set or invalid
jdsi.loglevel : 2
No External Component found
stream factory memory mode : no pooling
dsigen v1.138.4 - core v2.1
prop os.arch : sh4
prop jdsi.3SoftOSGi : true
DSI dispatcher disabled!
[t(p) proc/boot/procnto-instr 1 1 0 8807922e]
checkFreeMem: giving up searching for process pids
[t(p) proc/boot/procnto-instr 1 7 30 8807bd14]
[t(c) usr/bin/srv-starter-QNX 24584 3 30 804d9ba]
[t(p) usr/apps/NavCore 98340 16 12 838dcb0]
Unable to access /dev/hd0
*** Online Speech ***
*** EncodeStream ***
*** v1.0.02 ***
Пробовал запустить режим IPL , приглашение есть , но ввести ничего нельзя.
В режиме IPL выполнил команды
boot 1c0000slay -9 MMI3GEmergencyApp
flashit -a 40000 -e 1000
flashit -a 780000 -e 1000
вставил карту с прошивкой , прошивка пошла дисплей вылез , но остался чёрный минут через 10 перезагрузка и всё как было : дисплей не выезжает 5F не диагностируется.
Вот что после прошивки:
Duration of starting JDSIBundle : 50940ms
Starting next program at v8804bae0
Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3GP Build 9411 D1 E1-13324A
# NV: Waiting for the minirm init done indication file /dev/shmem/nvminirm.finished'
NVLOADER: Done
devg-NVMEM: Mapped vaddr 0x38100000 to paddr 0x5d597000
multicored [000000001.644]:version 4.6.d, verbosity 1 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
multicored [000000001.647]:using 750 buffers of size 1460 (total 1095000 bytes)
multicored [000000001.686]:version 4.6.d, verbosity 2 (supported 4), scope 0x00000001, console: /dev/ser1 (fd=3), FILE_LOGGING, TESTCONTROL, DYNAMIC_LOAD
multicored [000000001.707]:udp: broadcaster created
[pintest] Attaching nmi handler to 4096
[pintest] Attaching pci handler to 8245
[pintest] Applying NMI patch
multicored [000000001.749]:attached to filesystem at /hbsystem/multicore, port 851
multicored [000000001.780]:MACHINE:SH(1), total MEM 499122176, 1: 271582976 SH7785 (SH4A) 792MHz, FPU
multicored [000000001.789]:sloop active
multicored [000000001.791]:lo0 127.0.0.1 255.0.0.0
multicored [000000001.792]:pflog0 0.0.0.0 0.0.0.0
multicored [000000001.819]:listener_activate()
multicored [000000001.821]:listener on port 851 active, fd=7
common/include/NvRefCountImpl.h:134: NV_ASSERT failed: __INvRefCountIMPL_m_ulRefCount == 0
checkFreeMem: problem getting system time.Audi 3G+ dumper: dumping to /HBpersistence/core/GPIOSet.core.gz
core dumped for pid 45084
Inside Open to
closed.
Process 45084 (GPIOSet) terminated SIGSEGV code=1 fltno=11 ip=08043a5e ref=00000000
For further debug messages have a look at multicore output consoles '/hbsystem/multicore/navi/g'
[t(p) bin/waitfor 102429 1 10 70337228]
mam0 available
DSIVersion: 0.0.0
DSISource: DSI 2013_26_26
DSI-Build-Version: Mon Jun 24 11:14:01 CEST 2013 / DSIGEN v1.138.4
ReleaseLabel: Int_AU_EU_Front_SOP11_13321P
start JDSI bundle
[t(p) j9/bin/j9 143393 10 10 783ea7e6]
jdsi.loglevel : 2
prop os.arch : sh4
[t(p) proc/boot/procnto-instr 1 1 0 8807a22e]
[t(p) proc/boot/procnto-instr 1 4 30 8807cd14]
*** Online Speech ***FMod08363A_09441A
*** v1.0.02 ***
[t(p) usr/bin/srv-starter-QNX 24584 3 30 8045eee]
[t(p) usr/bin/srv-starter-QNX 24584 3 30 8044284]
[t(p) usr/bin/srv-starter-QNX 24584 3 30 804d7ba]
КАК решилось ? в чём была проблема. ?
