Как раз про 4кЕвро, письмо от фина.
hello,
I can sell You everything You need, including the hoses and connectors, but
You need to cut and fit the hoses into Your car Yourself, as they are
impossible to make "remotely". Making hoses is easy, and You don't need any
special tools.
Depending where You want to install the tank You need from 1000 to 3000 eur
for hoses and connectors. You also save a lot of money with hoses and
fittings if You route the oil lines under the floor instead of inside the
cabin.
How many chambers You want in Your sump pump? I recommend three stage
scavenge and one stage pressure. Two scavenges from sump pan and one from
turbo drain line.
Kit including:
-4 stage pump
-sump pan
-front plate incorporating pump bracket
-drive belt
-belt pulleys
-filter stand
-oil tank
price is 3850 eur incl. Finnish vat (22%)
You also may manage with 3 stage pump, in this case the kit is 200 eur
cheaper. Also of course plumbing is cheaper, as the system remains less
complicated.
Connectors and hoses:
an12 connector straight 31,2eur
an12 connctor 45 deg 61eur
an12 connector 90 deg 73 eur
an12 connector 180 deg 86 eur
an12 hose 63 eur / m
an12 through-wall coupler straight 23,5eur
an12 through-wall coupler 90 degrees 43,7
an12 Screen fittings to sump pan 64 eur / piece.
an12 twin coupler (for oil tank) 19,8eur
We use JLS superior quality connectors and hoses. Some connectors also come
from XRP. Do NOT use cheap-o chinese XRS fittings.
If You are familiar with dry sump systems, You know You need at least 15
fittings to make the plumbing.
Let me know if You want me to make You an exact offer with the amount of
parts I think You need?
Thank You
Jyrki
Pro-Mo
