Информация обновление
Показано с 1 по 20 из 22
    По умолчанию Информация обновление
    Привет всем,
    У меня есть 2010 A4 с MMI 3G DVD 2SD не HDD.
    Прошивка
    BNav_EU_P0022_D1
    корабли
    4G0919884N ЕЭК 5.17.2
    Мне нужна ваша экспертизу, чтобы выяснить, какая версия прошивки я могу использовать для обновления MMI и если после того, как даст мне проблемы с активации карты, потому что теперь я просто обновить FSC.
    спасибо
    English please
    Hello to all,
    I have a 2010 A4 with MMI 3G HDD DVD 2 SD no.
    the current firmware is
    BNav_EU_P0022_D1
    ships
    4G0919884N ECE 5.17.2
    I need your experience to find out which firmware version I can use to update the MMI system and if later I can give you problems with the activation of the card, so now I just need to update the FSC.
    thanks
    maxgiordan - You can install K0257 8R0906961DF sergeynik.com/mmi/8R0 906 961 DF.rar without previous updates
    у него 9304 юнит наверника
    sergeynik, I do not understand what you mean ... it's only for 9304?
    unfortunately I'm not familiar with the Russian and google translator is more disgusting to me
    for answer need main unit hardware version 930x
    where can I find the version hw?
    I tried the hidden menu but can not find it ...
    I apologize ... I'm poor in the field ...
    hidden menu
    Version release: P0022
    Software MU: 0048
    Dispositivo: B-BN-EU
    Numero SW: 8T1035652D
    Indice SW: 0048
    Data SW: 07.04.09
    Numero HW: 8T1035652D
    Indice HW: H52
    maxgiordan hidden menu: main/version/vesionmu, variant
    but I need the vag to enable the hidden menu?
    I'm sorry...you're wasting your time...
    You can activate hidden menu w/o vcds cable. Just need to run script
    Thank you friends ... I have to get a vcds ... otherwise I can not do anything.
    Should I go for strength in Ro-Te ** **
    Thanks again ... as opposed to other forums here who knows how to help beginners like me!
    maxgiordan run this script and you will have engineering (hidden) menu without VCDS
    http://yadi.sk/d/lkkgZO0TH7nVw
    Aha ... ok ... I copy the contents of the folder "greenmenu_on" in sd and boot setup + return ... right?
    no. unpack, copy content to sd root, insert sd to working mmi
    http://www.club-q5.ru/forum/showthread.php?t=4489 #2.9
    very interesting ... I'm trying to learn and put into practice ... thanks
    DUK63 great script!
    the green menu is enabled.
    MU Version: 0048
    Data base version: 5.17.2 4G0919884N ECE
    FPGA: Daycode: 28/49/2A
    GPS Version: 0
    HW version MU: d1 9303
    I repeat: I need your experience to find out which firmware version I can use to update the MMI system and if later I can give you problems with the activation of the card, so now I just need to update the FSC.
    Thanks SERGEYNIK, ДЮК, UKNIK, for the support ... this is a great forum!
    HW version MU: d1 9303 -
    I don't know
    I coded A4 2010 from Germany with MMI3G- Hardware has been 9308
    Последний раз редактировалось ДЮК; 11.03.2014 в 17:56.
