Hello,
are possible to change a Sw part nr. letter on MIB 2 with VAGPro like MMI 3G?
Hello,
Hi!
The software version is stored in EEPROM starting at address 0x3A0 (in ascii).
If you know how to read/write eeprom with VAGPro you can change it, I don't know how to use it.
Another solution is to use the console access from RCC and use modifyE2P binary.
example: /usr/apps/modifyE2P w 3a5 45 52 5f 41 55 47 31 31 5f 50 30 30 34 30
this will write in eeprom at address 0x3A5 the string ER_AUG11_P0040
Use it wise, if don't want to trigger component protection.
Cheers!
Последний раз редактировалось romanesh; 02.08.2017 в 08:58.
