ссылка из первого поста
http://www.034motorsport.com/product...products_id=56
Copper head gasket suitable for high output applications when used in conjunction with Head Studs and an o-ringed block.
Available in any bore size or gasket thickness, can be used to lower compression in I5 blocks that came with hydraulic lifter heads (does not fit with older solid lifter head blocks). Rubber coated for improved sealing.
In stock at .06" (equivalent to stock gasket thickness) and 83.5mm bore. Recommended only for use with o-ringed block or head.
