Audi MIB2 Wiring diagrams - Страница 2
Показано с 21 по 25 из 25
  1. #21
    Hi Guys,
    actual I trying to bring a A4 B9 MIB2 (Harman 8W0...) to work on desk.
    The Main Unit runs and communicates via internal MIB CAN to Keyboard and Display... The part No. recognition of the display was correct.
    But there is no picture on the 8W0 Wide Screen Display. Are there some changes in the LVDS connector between A6 MIB2 (4G1 035 021) and 8W0 family????
    The extra 4 pins for Ground, VCC and CAN of the enhanced LVDS connector must be correct. See above result.
    Some ideas or expiriences from your side?
    Thanks
    Tschako
    Problem was solfed! There was a wrong pinout used at the LVDS Adapter from Audi spare parts!
    Последний раз редактировалось Tschako; 13.02.2018 в 13:07.
  2. #22
    IT
    Цитата Сообщение от Tschako Посмотреть сообщение
    Hi Guys,
    Thanks
    Tschako
    Hello Tschako,
    how do you connect the main unit to keyboard and display on bench?
    Do you have a wiring diagram or something?
    Thank you
  3. #23
    Yes, of course! The inter-Component wiring ist shown on ErWin online... It´s all known...
  4. #24
    Hi there,
    I have an engineering background but I am kinda new for Automotive Multimedia systems. I need a help with setting up a MIB2 on desk and just reading the central unit status and communication. I got the following H/W:
    MIB2 Harman (4G1 035 025 D)
    Display (4G1919601R)
    Display-MIB2 Cable (8V1971551C),
    - What are H/W parts I am still missing?
    - Do I need the MMI Touch Pad?
    - What is the wiring should be done?
    - What software can I use to monitor the communication of the MIB2 unit? How I connect the setup to a PC?
    - Is there any thread in English I can read through?
    Thanks in advance,
    Sam
  5. #25
    Ok. It is working. However Bluetooth and Wlan are off, it needs the igniation on.
    How I can make the mib2 to think that ignation is on. Is there a CAN message I can send.
    Thanks.
