MMI3G / RNS850 Texts Editor
Показано с 1 по 10 из 10
    Moscow
    По умолчанию MMI3G / RNS850 Texts Editor
    Тулза для редактирования texts.jar для поиграться
    Mega / YD
    пароль turbo-quattro.com
    Изображения Изображения
    Последний раз редактировалось zerbino; 11.03.2016 в 22:45.
    Thanks Zerbino!
    Nice Tool!
    Whats about the field or border size of the character items? In the Drive Select Menu for example? They are fit?
    Последний раз редактировалось Tschako; 11.03.2016 в 18:50.
    Well, why is everyone so cold
    I said thank you
    Чтобы узнать от вас
    Seems a silly question, what file do we load into the software?
    Hey zerbino
    it seems that there is one small bug
    every text i change after save gets new line after the text.
    Do you know any fix for that ?
    Regards.
    Последний раз редактировалось congo; 16.09.2017 в 16:50.
    The problem code is here
    Код:
    		private void buttonEditSave_Click(object sender, EventArgs e)		{
    			string str = "";
    			for (int i = 0; i < this.EditTextBox.Lines.Count<string>(); i++)
    				str = string.Concat(str, this.EditTextBox.Lines[i], '\n');
    this will add "\n" new line for each line in the text box, but it should not add it for the last line.
    As i dont have the source is it possible to fix that and upload?
    Hi
    3g low (Bnav) navigation where text file do not know?
    In lsd.jxe in ifs-root lsd folder.
    You can modify it, copy outside of ifs-root as you cant rebuild that image and then also modify lsd.sh in efs-system lsd folder so you can use your modified lsd.jxe file.
    Hi
    Could you help me how to do it?
    I can but i dobt have 3G basic anymore on the bench
    Not sure how much free space it had in efs-system.
