I killed IPL:(
Показано с 1 по 10 из 10
Тема: I killed IPL:(
    По умолчанию I killed IPL:(
    I use SDcard script,commanded:flashit -a 0 -d -f /mnt/sdcard10t11/fs0
    • After a while black screen, JTAG terminal connection without any response
    Чтобы узнать от вас
    Before this I was using SD script did an experiment:flashit -a 0x00780000 -d -f /mnt/sdcard10t11/ifs-root.ifs
    Run crashed, connecting Terminal 780000 found dead,I use JTAG to restore
    I want to clarify two issues
    1、Flashit command run fish metainfo2 and JATG Terminal,And not with the SD script???
    2、Can I Flash the entire GL512 starting from address 0?
    If must be in accordance with the metainfo2 structure to Flash GL512, trouble
    Последний раз редактировалось audijiJQ; 05.08.2015 в 11:30. Причина: Finally, how to restore the IPL?
    Чтобы узнать от вас
    • Well, who can introduce a cheap JTAG, and application software? I try to use it to repair
    Чтобы узнать от вас
    Minsk
    you crazy
    In addition to FT2232, what does the appropriate JTAG support SH7785?
    Чтобы узнать от вас
    Киев
    You can desolder flashes and reprogram using flash device programmer.
    OK thanks~~
    Чтобы узнать от вас
    Has anyone ever tried in an emergency update interface using a script?
    I tried again, nothing happens.Only the terminal type commands
    Чтобы узнать от вас
    With JTAG, it is possible to flash the IPL, i did it with success
    Need a complete tutorial
    Чтобы узнать от вас
