если не ошибаюсь Bosch) EV14 fuel injectors. Rated at 47lbs/hr. Actual flow rate is 52lbs/hr.
Body Design: EV14, Composite plastic
Fuel Nozzle: 6-hole disc, awesome atomization!
Injector type: Saturated
Flow rates: (All tests conducted using the industry standard Heptane).
Flow rates: Actual tested rates listed
532cc at 2.7bar
550cc/min, 52lbs/hr at 43.5 psi. (3 bar).
585cc/min, 55lbs/hr at 49 psi. (3.5 bar).
635cc/min, 60lbs/hr at 58 psi. (4 bar).
Length: 2-3/8 inches, 64 mm
Diameter: 9/16 inches, 14 mm
Orings: Top and bottom, 14.5 mm, Viton
Resistance: 14.5 Ohms
Dead Time: 0.7ms at 14 volts
Electrical connector type: U.S. CAR, EV6
Part number available: 0280158117
