Audi A6 4G MIB Head Unit HIGH - Страница 2
Показано с 21 по 40 из 83
  1. #21
    Hi,
    what version of firmware are you using ?
    What is the path to the root-ifs.img (int the firmware) you dumped on your previous post ?
    MHIG_EU_AU_P1531/MMX1/mifs-stage1/40/default/mifs-stage1.img
    MHIG_EU_AU_P1531/MMX1/mifs-stage2/40/default/mifs-stage2.img
    these can not be dumped using dumpeifs - at least i don't know how
    regards
  2. #22
    I used this command : dumpifs - x ifs-root. ifs, the results suggested that : " Unble to open etc/symlinks.cfg : No Such file Or Directory "
    Чтобы узнать от вас
  3. #23
    which firmware ?
    in recent MIB Firmware there is NO ifs-root. IFS in the MMX directory !
  4. #24
    Цитата Сообщение от bertelsmann Посмотреть сообщение
    Hi,what version of firmware are you using ?What is the path to the root-ifs.img (int the firmware) you dumped on your previous post ?MHIG_EU_AU_P1531/MMX1/mifs-stage1/40/default/mifs-stage1.imgMHIG_EU_AU_P1531/MMX1/mifs-stage2/40/default/mifs-stage2.imgthese can not be dumped using dumpeifs - at least i don't know howregards
    E:\MHIG_EU_AU_P1531_(A3)\RCC\ifs-root\31\default\ifs-root.ifs
    Чтобы узнать от вас
  5. #25
    I need a firmware in China
    Чтобы узнать от вас
  6. #26
    release = "MHIG_EU_AU_P1531"
    MUVersion = "0356"
    vendor = "HARMAN (HAD)"
    variant = "FMU-H-N-EU-AU*"
    variant2 = "FMU-H-TN-EU-AU*"
    variant3 = "FMU-H-TNL-EU-AU*"
    variant4 = "FMU-H-ND-EU-AU*"
    variant5 = "FMU-H-TND-EU-AU*"
    variant6 = "FMU-H-TNDL-EU-AU*"
    region = "Europe"
    delMmeBackup = "true"
    MaxParallelDevices = "2"
    ExclusiveUpdate = "AMP12_APN,CINTERION,CINT-LTE,DUA201,DVD,FC1H37xE,KBD_FA3H,GPS,TELIT,Tuner"
    FinalScript = "./common/tools/0/default/finalScript.sh"
    FinalScriptName = "Final Script"
    FinalScriptChecksum = "e96f9282abd730c385a912a094e92d18a2fd5e26"-----I calculate the checksum and the same
    FinalScriptMaxTime = "20"
    MetafileChecksum = "ec75d57a2ec2d94c267abd987a866b7fdef9607d"-------I cannot compute the checksum is correct
    Чтобы узнать от вас
  7. #27
    I search a bit, as if made by RSA+32 - Bit hash is encrypted
    Since the document was handed over to J794 to read, then the public key inside the J794
    So the private key???
    It's like FSC, we only know the public key in J794, no one knows the private key
    If someone knows they will never be said? The leak, is illegal
    Чтобы узнать от вас
  8. #28
    Minsk
    may be you need this
    Вложения Вложения
    • Тип файла: zip Keys.zip (4.5 Кб, Просмотров: 357)
  9. #29
    the word public in the key's name says it all
    if you find the same files with "private" instead of public
    please post it :-)
  10. #30
    My friend,All public key
    But,Your product a lot
    Чтобы узнать от вас
  11. #31
    Germany
    Hi!
    Is there any chance that someone can share the firmware update? MHIG_EU_AU_P1531
    Thanks!
  12. #32
    Germany
    Hello!
    Nobody shared the FW update, I don't know why..
    I managed to find it on different forum. Some help for you for the moment:
    Emergency boot root password is "harman_f"
    If you already knew it, maybe you can share the normal boot root password.
    Regards!
  13. #33
    Maybe use solution on VW site for POI update:
    Metainfo2.txt:
    # This is the description file for the Software Update of Volkswagen components
    [common]
    skipSaveTrainName = "true"
    vendor = "ESO"
    skipCheckSignatureAndVariant = "true"
    region = "Europe"
    region2 = "RoW"
    region3 = "USA"
    variant = "FM?-H-*-*-*"
    release = "2012/2013"
    UserSWDL = "true"
    skipMetaCRC = "true"
    MetafileChecksum = "3eae301545686f06bcf04e896a1e98e1f1340458"
    skipFileCopyCrc = "true"
    [PersonalPOI]
    VendorInfo = "ESO"
    DeviceDescription = "Personal POI Packages"
    ConfigComponent = "PersonalPOI"
    PacketName = "Package"
    ConfigCheckPath = "PersonalPOI/Package/0/default"
    ConfigFinalizePath = "/net/mmx/mnt/navdb/PersonalPOI/Package"
    IncludeModules = ",Package,"
    [PersonalPOI\Package\0\default\Dir]
    CheckSumSize = "524288"
    CheckSum = "51f3f6ea627c19fb640d1bcdfb7f3787c325dc3c"
    FileSize = "198486"
    CheckType = "CheckReadData"
    DeleteDestinationDirBeforeCopy = "true"
    Version = "1"
    UpdateOnlyExisting = "false"
    IsDestinationInFFS = "false"
    Source = ""
    Destination = "/net/mmx/mnt/navdb/PersonalPOI/Package"
    DisplayName = "Personal POIs"
    [PersonalPOI\InfoFile\0\default\File]
    CheckSum = "1abf1ee7e070c8faf74e774f0991733f0d59835a"
    FileSize = "640"
    Version = "3"
    Source = "Update.txt"
    Destination = "/net/mmx/mnt/navdb/PersonalPOI/Update.txt"
    DisplayName = "Database Information"
  14. #34
    Does anyone know which cars these MIB2 updates are for? I have collected the following information as I am trying to find updates for a Q7 4M. Factory was 0358, then 422, 678 and now 917 with SQ7
    SD Card Name (ETKA) Release MIB Ver VARIANT Vehicle
    4M0906961 P0040 A6
    4M0906961A MHI2_ER_AUG24_K1068 1068 TT3
    4M0906961B MHI2_ER_AUG22_K2140_1 358 Harman (HAD) Q7
    PRODUCTION FACTORY MHI2_ER_AUG22_P2133 358 Harman (HAD) Q7
    PRODUCTION FACTORY MHI2_ER_AUG22_P3241 678 Harman (HAD) Q7
    PRODUCTION FACTORY MHI2Q_ER_AUG22_P3638 917 Harman (HAD) SQ7
    4M0906961C MHI2_ER_AU57x_K2519_2 389 Harman (HAD) A6/A7
    4M0906961D
    4M0906961E
    4M0906961F
    4M0906961G
    4M0906961H BDT_AU536_0165 165 Q7
    4M0906961J
    4M0906961K
    4M0906961L
    4M0906961M
    4M0906961N MHS2_EU_AU_K0129 159 DELPHI A4/A5
    4M0906961P MHS2_ER_AU_K0465 175 Q2/B9/A3
    4M0906961Q MHI2_ER_AU57x_K2570 924 Harman (HAD) A6/A7
    4M0906961R
    4M0906961S
    4M0906961T
    4M0906961AA
    4M0906961AB
    4M0906961AC
    4M0906961AD
    4M0906961AE
    4M0906961AF
    4M0906961AG
    4M0906961AH
  15. #35
    Стокгольм
    latest:
    4M0906961AJ
    4M0906961AK
    4M0906961AL
    4M0906961AM
    4M0906961AN
    Последний раз редактировалось nikolajse; 18.05.2017 в 21:12.
  16. #36
    Стокгольм
    No - I can just see that they can be ordered...
  17. #37
    That's true ... but in the end of the file you will find digital signature
    And that's something you cant calc.
  18. #38
    4M0906961Q SD Card:
    35eur, any audi dealer.
    1\metainfo2.txt
    2\metainfo2.txt
    metainfo2.txt
    Вложения Вложения
  19. #39
    Egon, are you able to provide us the whole SD card image? This would be fine!
    Herr Frei
  20. #40
    Does anyone have IOC app image version 8285 ?
    Regards.
