03157 - Functionality limited due to Communications Disruption
Показано с 1 по 5 из 5
    italy
    По умолчанию 03157 - Functionality limited due to Communications Disruption
    Hi,
    can someone tell me a way to solve definitely this error in 5f?
    Thanks
    Hi
    http://www.club-q5.ru/forum/showpost...&postcount=605 #4
    Check the coding and the settings CAR menu in the green menu: either you have something included in the green menu, then the car is not, or vice versa. In short it is necessary to configure and coding the MMI to be aligned with the real cars filling the options
    only this
    italy
    Цитата Сообщение от ДЮК Посмотреть сообщение
    Hi
    only this
    Ok. As always thanks very much
    Yesterday I installed the ADS and after installation this error compared in the 5f.
    It is strange because I enabled ADS in the green menu and then this error shouldn't have been shown.
    I'll let you know.
    Bye
    It may happents because then you include options to ADC witch not installed on you car. options like magnetic
    italy
    Hi ДЮК
    as always you are right.
    It was a temporary error because when I installed the ADS I forgot to check a bit in the 09.
    When I checked it the error went away and today there is no trace of it.
    Thanks again
