Hello guys,
first I want to say that you all do a great job on modifying the MMI.
Do you think it could be possible to run the wifi in Client mode to tether it to a mobile phone for 3G Data for gMaps and so on?
It could be possible if the driver an the QNX version do support WPA in client mode.
I already tried to make a run.sh which tries to set the wifi to unencrypted client mode but for now it was not succuessful. And before mid of the weekmI cannot work on this.
The MMI seems to run QNX version 6.3.2
Binaries for this version are not freely available.
Binaries have to be compiled for instruction set SH4
The compile target is SH4 - in newer QNX versions (from 6.4.0) even USB Wifi drivers are available. Maybe they could also work under 6.3.2.
If there is someone out there with knowledge of Linux networking, compiling for SH4 or working with QNX this would be very helpful.
See http://www.qnx.com/developers/docs/6...ackground.html for config hints.
Happy easter
Daniel
