How to extract a IFS file - Страница 3
Страница 3 из 5 ПерваяПервая 12345 ПоследняяПоследняя
Показано с 41 по 60 из 89
  1. #41
    Hey,
    i also do not know how to recompress again :-(
    i just know it is lzo compresed
    probably we have to write our own packer
    right now i do not have enough time for that :-(
    but i am also very interested in having a customized small ifs
    for maintainance purposes
    regards
  2. #42
    Polska
    As I wrote earlier, we have created a program to re-compress IFS file.
  3. #43
    London
    @Wladek,
    I am also creating a program. I can uncompress into a single file and re-compress IFS ok at this time, using 64K block size and LZO. If I unpack and repack IFS with no changes binary compare same, but if I change I am not able to calculate correct checksum Do you have any more info? Is standard polynomial?
  4. #44
    @Bedrock, wow great
  5. #45
    As far as i know the uncompressed ifs has to be compressed by LZO. There are some large unneeded files in the ifs the nvidia driver for instance.
    Is it a possibility to replace the area in the ifs where the nvidia driver is located with zero's. And then recompress again, 00 wil have maximum compression.
  6. #46
    London
    Seems ifs-emg doesn't use LZO compression after all, but instead uses similar UCL compression, need to update my tool to support both ifs-root and ifs-emg
    Byte 0x06 of ifs header seems to indicate compression method, maybe others already knew
  7. #47
    Bedrock, checked it see the result of a scan command:
    Entering CLI, type '?' or 'help' for help
    => scan
    ** @0x80100000: FPGA
    total size: 746480 [0x0b63f0]
    data: 746212 [0x0b62e4]
    .FDR = PL_MMI3G_PLUS_FPGA_9411_D1_09422A
    .FDU = Userinfos zu FPGA 9411_D1_4010_14lw
    ** @0x801c0000: IFS [vers.1, UCL, old EMERGENCY]
    total size: 4666284 [0x4733ac]
    - header: 256
    - startup: 53512
    - imagefs: 11565604
    RAM: 11619116 [0xb14b2c]
    ** @0x80780000: IFS [vers.1, LZO, old APPLICATION]
    total size:36867924 [0x2328f54]
    - header: 256
    - startup: 53512
    - imagefs: 85872380
    RAM: 85925892 [0x51f2004]
    === DATA CHECKSUM ERROR! ===
    ** @0x87f00000: BIOS packet
    total size: 786432 [0x0c0000]
    BIOS pattern: FFFFFF7F.FFFFFFFF
    App. pattern: FFFFFF7F.FFFFFFFF
    Is hard to notice, great finding
  8. #48
    Melbourne
    Радость
    Hi Guys,
    New to this forum but it is an honour to be here; I have a bricked MMI 3Gp, total black screen, I have been looking after a process how to recover it and I found a lot of information here on this forum. So thank you all!
    The challenge for me was to understand information in Polish and Russian, so to help others (just like I got helped by here) I managed to put an English version of step-by-step document together.
    Please find it attached here Recovering a dead MMI 3G.pdf (UPDATED 26-May-2014)
    Please note the attached PDF to this post is single release, the living verison of the document will reside here: http://www.scribd.com/doc/225614389/...ed-Audi-MMI-3G
    Regards,
    KG
    Последний раз редактировалось keldo; 28.05.2014 в 03:50.
  9. #49
    keldo,
    thank you very much for putting all this in one document !!!
  10. #50
    Местный Аватар для zerbino
    Moscow
    Цитата Сообщение от keldo Посмотреть сообщение
    Hi Guys,
    Please find it attached here Вложение 26270
    Regards,
    KG
    Dear foreign visitors! Please, when translating forum materials and shareing information from this forum, specify the source. At least in respect to the work of those who gave it all in the open access.
  11. #51
    Melbourne
    Zerbino, assuming your message is directed to me. I would like to draw to your attention to the following facts in response to your message:
    Цитата Сообщение от zerbino Посмотреть сообщение
    When translating forum materials and sharing information from this forum, specify the source.
    1. In my defence I have mentioned in my post that the content is a collection of information from this forum. The reality is, only the major portion of the content is from this forum, a lot of other information is complementary value-add from my end, which I have collected from various other sources.
    2. Documents were can not be translated, reused or modified have to carry copyright notices, so there are no disappointments, embarrassments or infringements.
    3. Words such as 'honour to be here' in my option are respectful enough.
    4. I'm getting a vibe that a lot of contributors of this forum that perform their research, hacking and development are looking for financial reimbursement. Which I completely agree in order to continue their great work, but the same contributors are also unhappy about release of my document.
    Further discussion and outcome of this; you and I can discuss in private, only if that puts you in a better level of confidence.
  12. #52
    Moscow
    Даже и дискутировать не интересно на эту тему
  13. #53
    Hello all,
    I try for several days to extract MMI3Gapplication from 783 FW from ifs-root.ifs with QNX dumpifs tool but it doens'nt work :-(( (The app crashs when I put the -z option)
    Other question.
    My car get MU9411/ifs-root.ifs(51). Do I extract ifs-root.ifs from 41 or 51 folder ?
    Here is the link https://www.sendspace.com/file/1l7s0t
    Does anyone can help me please ? :-))
  14. #54
    London
    Fully extracted IFS for you (both 41 and 51)
    https://mega.co.nz/#!thVhUKYa!ubYf3E...F71yl06m6PaqZo
  15. #55
    Waouh !!!! Many many many many many thanks Bedrock !! Really great job.
  16. #56
    Zürich, Switzerland
  17. #57
    Ступино
    Цитата Сообщение от unbe Посмотреть сообщение
    А скомпилированную версию под винду можно?
    Заранее спасибо
  18. #58
    Hello !!
    I need a new ifs to be extracted. Does anyone can do for me please ? Dear Bedrock it would be great if you could or anyone ?
    https://www.sendspace.com/file/bwyyzs
    Thank you in advance.
  19. #59
    London
  20. #60
    Bedrock you're the best ....... as usual.
    Thank you so much !!
