How to extract a IFS file
Показано с 1 по 20 из 75
    По умолчанию How to extract a IFS file
    Hello,
    I want to create a custom ifs-EMG.IFS file for repairing a MMI3G. With dumpifs it should be possible to extract a IFS, but it gives an error "Unable to find startup header in ifs-emg.ifs".
    Did i forget some parameters.
    Киев
    Give your IFS and i'll extract it for you.
    Slav,
    My goal is to have a ifs file for a 3GP smaller than 3 mb, so it can be uploaded to my 3GP unit.
    During the tranfser the unit goes to sleep within 5 or 6 minutes during the z modem transfer (10kbps), so the original ifs-emg upload is stopped. I tried a ifs-emg from a 3G unit that is about 3mb and it transfers by zmodem and the unit tries to boot with it, the architecture of a 3G is different so it stops.
    I have put a image on this link:<link deleted>
    Is it possible to create a new ifs from the extracted with makeifs then, with a new build file.
    Последний раз редактировалось theed; 13.04.2014 в 23:50.
    Киев
    Unfortunaly, i can't make new image for zmodem. I can only unpack your image.
    BTW, your link doesn't work.
    need MU version
    The Mu version is:
    IPL: Audi 3G 9308 (SH7785) / QNX 6.3.0 [PL_qnx_ipl-3g_9308-sh7785_08253A, built 2008/06/18_15-16-25_UTC]
    CPU: SH7785 (>= 5th cut, clk mode 20. 4xDDR), 792MHz
    RAM: 512 MB (probed, DBCONF=e30002)
    FLASH: Spansion S29GL512N (32bit): 512 sectors x 256K
    FPGA: PL_MMI3G_PLUS_FPGA_9411_D1_11384A (0ms)
    *** Old-fashioned mark found on IFS @0x1c0000: .zero=0x30000013
    *** Old-fashioned mark found on IFS @0x680000: .zero=0x10000000
    RAM : 128 MB @0x08000000
    RAM : 128 MB @0x40000000
    NVRAM: 36 MB @0x5dc00000
    RAM : 220 MB @0x50000000
    FLASH: 128 MB @0x00000000
    FPGA IRQ: Interrupt Controller ID:33 Ver:2.1.0 ILVL:7 Lines:255
    System page at phys:0800a000 user:0800a000 kern:8800a000
    Starting next program at v8804bae0
    Welcome QNX6.3.2 (QNXLabel RL_qnx_os_632_PSP3_08041A)- Harman/Becker MMI3GP Build 9498 E1-12032B
    USB-stuff (QNXLabel RL_qnx_os_632_PSP3_08041A)
    Train ID: HN+_KR_AU3G_P0553 (or higher in case of train updates without MU change)
    Release Candidate: 1.0 (or higher minor version)
    MU version: 0553
    before i flashed it i wrong adress (forgot one 0 at the end of the adress).
    Последний раз редактировалось theed; 19.03.2014 в 00:31.
    Any news on That?
    Well unpacking is not a problem,
    either change a few bytes in the ifs header so that dumpifs (qnx tools) can handle it
    or write your own little extraction tool. IFS is LZO compressed - once you decompressed it
    it is the normal ifs structure.
    but did anybody succeded in repacking it into an working ifs image (buildfile)
    which the mmi ipl accepts - i did not :-(
    Any help appreciated
    regards
    No, i did not succeed in extracting the ifs yet.
    My idea was to extract the ifs, create a new buildfile and rebuild a (smaller) ifs.
    Which bytes do i have to change, i will give it a try?
    As far as i know Sergeynik can make a new IFS.
    Hi,
    get the qnx developer tools.
    There is a tool called dumpifs
    on older firmware images (before 612 i guess) this worked
    do either change byte 0x37 from 01 to 00
    or use the option -z
    dumpifs -zx image.file
    if you changed the bit 0x37 you do not have to use the -z option
    since version 612 ifs is compressed in a different way
    i am not sure if there is a way to decompress with dumpifs
    regards
    Moscow
    Цитата Сообщение от bertelsmann Посмотреть сообщение
    Hi,
    regards
    Hi! If i can view statistics of ifs-root.ifs by command dumpifs ifs-root.ifs like at феефсрув file, does it must be unpacked by this utility or not?
    i type dumpifs -x ifs-root.ifs but only have output like
    Код:
    Checksums: image=0xe4ba088a startup=0xeb3f2b45
    and no any files exists.
    Is it posible get content of ifs-root.ifs or it have some nuances?
    ifs-root-ls.txt
    I used the command like this:
    dumpifs -z -d d:\dump\ifs-emg\ -b d:\dump\ifs-emg.ifs
    It gave me a dump of the file in the d:\dump\ifs-emg\ directory, without the -b i get an error that it was unable to open a directory.
    The -b is for dumping in the root of the directory, i did not change the byte 37
    After investigating the extracted files there is one nvidea driver file of 2mb, if i can get rid of that file there is enough time to reflash the unit.
    Must be possible to generate a new buitldfile from some qnx examples on the web, and then make a new one by makeifs.
    Ill keep you updated.
    you have to create the directories first
    try something like this:
    IMAGE=$1
    echo "Dumping content of $IMAGE..."
    $IFSDUMP -z $IMAGE |awk '{print $3}' >$TMPDIR/ifscont.txt
    $IFSDUMP -z $IMAGE |grep "\->" |awk '{print $3" -> "$5}' >$TMPDIR/ifslinks.txt
    for i in `cat $TMPDIR/ifscont.txt`; do dirname $i; done |sort -u >$TMPDIR/dirlist.txt
    for i in `cat $TMPDIR/dirlist.txt`; do mkdir -p ./$i; done
    #create symlinks
    while
    read i
    do
    SRC=`echo -e "$i" | awk '{print $3}'`
    LNK=`echo -e "$i" | awk '{print $1}'`
    LNKDIR=`dirname $LNK`
    LNKBASE=`basename $LNK`
    cd $LNKDIR
    ln -s $SRC $LNKBASE
    cd $CURDIR
    done < $TMPDIR/ifslinks.txt
    $IFSDUMP -zx $IMAGE
    echo "done !"
    Thanks, bertelsmann
    Now i have a normal directory structure, anybody luck with a build file to use makeifs, and use a custom version?
    Still going through the qnx manuals to find out what it should have been.
    Киев
    Good luck ))
    sergeynik, do you have any info, regarding a buildfile?
    Nicaragua
    Вы будете нуждаться в QNX строителя = лицензию QNX, или попробовать использовать оценивается версию - в течение 30 дней.
    http://www.qnx.com/developers/docs/6...e/builder.html
    Киев
    А всё остальное Пушкин напишет? Стартап код, наприер? Не морочьте голову ))
    Nicaragua
    Я могу понять ваше русски, потому что Google Translate, плохо переведены. Мы не говорим о написании scripts и программирования на языке Java, но QNX строитель, что создаст флэш изображения EFS и другие параметры вашего 3G + в.
    Если это так, то вы "Пушкин" делают нас одной EFS вручную...
    уверен, что есть пути для хороших программистов, чтобы dissasemble EFS IMG и т.д., но здесь, в основном новички, и именно поэтому я предложил QNX строитель, потому что я не видел много разработчиков здесь, за исключением Sergeynick и Uknik, может быть, у вас есть еще один «Пушкин "Р?
    Киев
    Вы название темы видели? Тут речь идёт об IFS, а не EFS. Вас что интересует? EFS не надо редактировать. Зашейте образ во флеш, монтируйте, сделайте изменения и сделайте дамп. С IFS всё гораздо сложнее. Не хотел вас расстраивать, но, QNX IDE не поможет, и билд файл тоже. Сделать билд можно, но, стартап код, необходимый для загрузки системы, есть только у производителя.
    И, да, я собирал образы билд-файлами, для других устройств, и знаю о чём говорю.
