Firmware update on my Audi A4 B8...
Показано с 1 по 4 из 4
    Вопрос Firmware update on my Audi A4 B8...
    Hi,
    I am actually looking to update the FW of my A4 B8 (end of September 2009 so assume MY 2010 )
    I own a MMi 3G (the one with Carto on DVD and 2 SD card ports...and so no HDD).
    Actual version is:
    I copied K0257 update files on an SD card, put it in SD1 port and try to launch the Fw update, I get this screen:
    [/url]
    If I try to go ahead, I then get this error (or warning in fact) screen:
    Translation:
    WARNING: The software can became inconsistent
    ...using the scroll button, on the bottom I can proceed with update if I'd like:
    So, is K0257 the compatible version for my car??
    Can I go ahead without any problem??
    Thanks in advance for your support,
    BR
    Последний раз редактировалось dave chante pas; 12.03.2014 в 01:25.
    It seems that you have MMI 3G Basic.
    You can try this updates for 3G Basic EU: 8R0906961AG -> 8R0906961AH -> 8R0906961BD (BNav_EU_K0206_2_D1) -> 8R0906961CG -> 8R0906961DK
    (from http://en.wikipedia.org/wiki/Multi_Media_Interface)
    You must use 256.
    Problem solved!
    I was able to update to K0257 without problem...I simply use the K0257 Software update for variant 9303/9304 instead of 9307/9308 which create the issue mentionned
